Author Topic: Black&White Keycaps, help needed!  (Read 2221 times)
Offline altdrugz
« on: Tue, 30 April 2013, 21:12:10 »
Hello everyone,
I have the 87-key US ANSI layout Leopold "Otaku" keyboard and I want to turn it into something similar to
http://www.picpaste.com/mkp_key-K6Kulj47.JPG
Any ideas?
PS: http://keycapsdirect.com/key-caps.php Havent figure out what kind are the "default" ones? :S KT?
« Last Edit: Tue, 30 April 2013, 21:13:57 by altdrugz »
Offline Hyde
  • White Tofu Extraordinaire
Re: Black&White Keycaps, help needed!
« Reply #1 on: Tue, 30 April 2013, 21:27:17 »
Just buy this http://www.wasdkeyboards.com/index.php/87-key-cherry-mx-keycap-set.html then swap every other keycaps then you'll be set  :D
Though keep in mind you have to keep your black spacebar on because Leopold has non-compatible spacebar stem spacing.
Filco Spacebar VS Leopold Spacebar
« Last Edit: Tue, 30 April 2013, 21:30:35 by Hyde »
