Author Topic: C++ Study Help? [solved]  (Read 2606 times)
Offline Lastpilot
  • Power stance
« on: Wed, 01 May 2013, 19:51:17 »
Given the function definition
void Test (/* in */ int alpha)
      static int n = 5;
      n = n + alpha;
      cout << n << ' ';
what is the output of the following code? (assume Test has not been called previously)
Test (20);
Test (30);
The answer is 25 55.....why isnt it just 25 35?
« Last Edit: Wed, 01 May 2013, 20:07:50 by Lastpilot »
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: C++ Study Help?
« Reply #1 on: Wed, 01 May 2013, 20:01:37 »
static.  It remembers.
Re: C++ Study Help?
« Reply #2 on: Wed, 01 May 2013, 20:02:18 »
What he said.
Offline Lastpilot
  • Power stance
Re: C++ Study Help?
« Reply #3 on: Wed, 01 May 2013, 20:05:29 »
So does that mean that the "= 5" part doesn't matter on the second function call?
Re: C++ Study Help?
« Reply #4 on: Wed, 01 May 2013, 20:06:35 »
Yes, once it is initialized it doesn't get initialized again.
Offline Lastpilot
  • Power stance
Re: C++ Study Help?
« Reply #5 on: Wed, 01 May 2013, 20:07:32 »
Ah okay I get it. Thanks guys!
Offline hashbaz
  • Grand Ancient One
Re: C++ Study Help? [solved]
« Reply #6 on: Wed, 01 May 2013, 20:11:01 »
Note that reinitializing n each time would defeat the purpose of declaring it to be static.  It would have no way to retain its value between calls.
Offline jalaj
« Reply #7 on: Wed, 01 May 2013, 21:32:20 »
static int n = 5  /* or just use int n = 5 */
      alpha = n + alpha;
      cout << alpha << ' ';
that should return what you're looking for
test(20) -> 25
test(30) -> 35
« Reply #8 on: Wed, 01 May 2013, 21:33:37 »
That is not correct code.
