Author Topic: The ”correct way” of typing on a blue switcjes keyboard?  (Read 2476 times)
Offline linziyi
  • The one with many questions
Hi there! I just got my first board today, it's a quick fire TK with cherry mx blue.  It feels amazing but if I try to avoid bottoming out (as I always do on my rubber dome), my hands become quite stress... Is there an "optimal" way of using a blue switches keyboard? Thanks a lot for advices!!!
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Re: The ”correct way” of typing on a blue switcjes keyboard?
« Reply #1 on: Thu, 02 May 2013, 02:46:40 »
If you're talking about ergonomics that's realm for science and specialists, but here... well bottoming out isn't everyone's cup of tea.  Although there's a lot of people who love to do it on a Topre switch.  I believe the optimal way to use any switch is to get to actuation and finish the sentence if you know what I mean :3
Good luck and godspeed you on your road to recovery from this addiction.
Offline stingrae
« Reply #2 on: Thu, 02 May 2013, 03:26:52 »
Most people get sort of more used to the tactile point as time goes on. I would suggest trying to type normally and let the switch adjust your way of typing naturally as eventually bottoming out becomes an unfavourable action.
Filco Ninja Tenkeyless  -Noppoo Choc Mini - Cm Storm Quickfire Rapid
Offline TheQsanity
  • SmallFry Lovin'
« Reply #3 on: Thu, 02 May 2013, 03:27:58 »
Just bottom out. Your ears will tell you.
SmallFry! <3
Offline Grim Fandango
« Reply #4 on: Thu, 02 May 2013, 04:52:18 »
I think this can only be done overtime through muscle memory. At some point , your hands will remember the exact force and travel necessary to register a keystroke. Do not worry about it, you are not doing anything incorrectly by bottoming out.
Offline esoomenona
  • Gnillort?
« Reply #5 on: Thu, 02 May 2013, 05:08:14 »
For me, Blues are really light, and bottoming put is pretty much inevitable. As people mentioned, don't try to force something that puts unneeded stress on your hands for nothing. If you don't want to bottom out and can't help it with Blues, maybe you need heavier switches (or heavier springs swapped in).
Offline davkol
  •  Post Editing Timeout
« Reply #6 on: Thu, 02 May 2013, 06:44:20 »
Soft-landing pads may help you. They definitely helped me when typing on blues, because I couldn't avoid bottoming out, and it was annoyingly loud. In fact, I could barely hear the click.
Offline blututh
« Reply #7 on: Thu, 02 May 2013, 06:48:20 »
u need o-ring sir
« Reply #8 on: Thu, 02 May 2013, 06:54:52 »
I bottom out when I type on blues and I have soft-landing pads on my Leopold. It's an amazing combination for me.
Offline davkol
« Reply #9 on: Thu, 02 May 2013, 07:15:42 »
u need o-ring sir
When it comes to blues, soft-landing pads > o-rings IMHO.
