Author Topic: Corsair Vengeance m65  (Read 2877 times)
Offline drynnn
« on: Thu, 02 May 2013, 07:05:57 »
Anyone have experience from thism mouse?Thinking of getting it . ;D
Offline BADBADNOTGOOD
Re: Corsair Vengeance m65
« Reply #1 on: Thu, 02 May 2013, 12:10:32 »
They red button is placed to far to be pressed comfortably with your thumb and its an unprogramable dpi lowerer
I suggest you get the m95 instead
Offline drynnn
« Reply #2 on: Thu, 02 May 2013, 14:27:36 »
Ok, are there any other mouses u would recommend to get?
« Reply #3 on: Thu, 02 May 2013, 20:30:00 »
The razer deathadder seems to be really popular but i would never own a razer product even if the mouse is the best thing they make...
On the cheap end you have the logitech G500 and if you can find a steelseries Xai (disscontinued as of a couple months ago) they are pretty good
Zowie FK is the successor to the AM which appears to be getting great reviews
I know there are some roccat products with an ADNS-9800 sensor (roccat kone pure color is the only one off the top of my head... has to be the color model though)
If you like the steelseries Xai but cant find it you could get the steelseries sensei raw which is the exact same thing but with a ~$60 price tag
The level 10 m has a good sensor and was created by BMW but is in the $90 range
 M95 is my favorite of the bunch due to its looks, extra "mmo buttons," and ands9800 sensor
I know some new mouses have been released like the g700 but i havent had the time to research any of the new releases. Overclock has a nice mouse forum if you want to check that out.
