Author Topic: Dip switches for USB hub in HHKB Pro 2?  (Read 5094 times)
Offline 2097
« on: Mon, 09 June 2008, 13:43:57 »
My USB mouse works fine but my small UMS doesn't; is there a dip switch I need to toggle?
Offline sashomasho
« Reply #1 on: Mon, 09 June 2008, 16:31:26 »
Quote from: 2097;5267
no, check your cable, if it is too thin and if it connects to only one of your computer's usb ports, then more power hungry devices might not work. i use one which has two normal usb connectors (one for data and power and the other only for power, both of which combine) at the one end and the other end is the mini usb connector, even my portable usb hard disk works attached to the hhkb with this cable...
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #2 on: Mon, 09 June 2008, 16:36:52 »
what's a UMS?
Offline sashomasho
« Reply #3 on: Mon, 09 June 2008, 17:08:50 »
Quote from: xsphat;5270
what's a UMS?
i suppose it's universal mass storage (device)... i thought it's how the americans call it, but as it seems it's not quite like that :)
Offline xsphat
  • Enlightened
« Reply #4 on: Mon, 09 June 2008, 17:17:34 »
so an external HDD? mine messes with my something and causes my computer to not shut down properly when I connect it to a hub (in OS X 10.5)
Offline 2097
« Reply #5 on: Tue, 10 June 2008, 03:38:26 »
Thanks. I'm using the cable that came with the keyboard. Guess I'll look into getting a better one.
Yeah, by UMS I meant a USB "thumb drive". I've got a UMS hard drive that I'd like to use, too, but I've only tested the "thumb drive" for now.
USB Mass Storage.
Offline sashomasho
« Reply #6 on: Tue, 10 June 2008, 06:07:58 »
Quote from: 2097;5282
My hhkb came without a cable :(
Offline iMav
  • geekhack creator/founder
« Reply #7 on: Tue, 10 June 2008, 07:45:35 »
I've plugged in digital cameras, thumb drives, external drivies, and even a printer (once, for initial setup) into HHKB Pro 2 and have had no problems.
Offline 2097
« Reply #8 on: Tue, 10 June 2008, 08:24:59 »
What dip switch settings do you use, iMav?
Offline iMav
« Reply #9 on: Tue, 10 June 2008, 08:35:49 »
Quote from: 2097;5289
Switch #2 "ON"...all the rest "OFF".
Offline 2097
« Reply #10 on: Tue, 10 June 2008, 08:51:54 »
Thank you.
Offline djones
« Reply #11 on: Tue, 10 June 2008, 15:48:33 »
not sure what it's called, but my 2.5 inch hard drive enclosure came with a usb cable that has 2 connectors on one end, to get extra power. using one of theose to connect the HHKB pro II may supply enough power to more devices.
