Author Topic: Gaming Mouse  (Read 10010 times)
Offline drynnn
Gaming Mouse
« on: Thu, 02 May 2013, 14:30:49 »
 Any recommended mouses to buy? Not so expensive ones ;D
Offline Rendom
Re: Gaming Mouse
« Reply #1 on: Thu, 02 May 2013, 14:35:33 »
Steelseries Sensei [Raw]- any type.(glossy,rubberised or frost blue)
Razer deathadder.
QFR - MX Blue
Offline baldgye
  • Will Smith Disciple
Re: Gaming Mouse
« Reply #2 on: Thu, 02 May 2013, 14:36:24 »
Steelseries Sensei [Raw] rubberised
Literally just ordered one of those
Offline drynnn
Re: Gaming Mouse
« Reply #3 on: Thu, 02 May 2013, 14:44:34 »
What about CM Storm Sentinel Advance 2 ? ;D
Offline JPG
  • Model F is my new passion!
Re: Gaming Mouse
« Reply #4 on: Thu, 02 May 2013, 15:03:36 »
I recommend the razer deathadder 2013. Very nice mouse. Fits well with palm and claw grip. Very good sensor.
In the end, if the design fits well with you hand go for it. Personally, what I find the hardest when choosing a mouse is being sure it will fit well with my hand (size, grip). But I must say that this one is very versatile in that regard.
The price is not cheap but it is not overpriced either (around 70$ +- 10$ I suppose)
Offline BlueBär
Re: Gaming Mouse
« Reply #5 on: Thu, 02 May 2013, 15:15:49 »
I have a DA 2013 as well. With the LEDs turned off this mouse is not only one of the best mouses with a flawless sensor but also one of the best looking (I mean it's ok if people like the green scrollwheel glow, but I personally can't stand the pulsating Razer logo). Has a very nice finish and the rubber on the sides is nice as well (I tend to get sweaty hands and this feels a lot better and more grippy than my previous mouse, a Microsoft Sidewinder). However you should always try a mouse first in a store if possible, also take a look at this list: http://www.esreality.com/index.php?a=post&id=2024663
Re: Gaming Mouse
« Reply #6 on: Thu, 02 May 2013, 19:03:41 »
Thermaltake Theron.  It's a nice mouse.
Re: Gaming Mouse
« Reply #7 on: Thu, 02 May 2013, 19:22:57 »
Logitech G400, Razer Deathadder Black, Mionix Naos (3200, 5000, or 8200), Microsoft Wheel Mouse Optical, a couple of Cooler Master mice.  And avoid anything R.A.T.
Offline Jocelyn
  • 조셀린
Re: Re: Gaming Mouse
« Reply #8 on: Thu, 02 May 2013, 19:46:09 »
This^ depending on what grip you use. I love my 8200 :)
« Reply #9 on: Thu, 02 May 2013, 20:08:37 »
My 5000 is one of the best mice I have ever owned.  For OP, the 8200 is an improved version of the 5000, but without a weight kit.
Offline gliy
Re: Gaming Mouse
« Reply #10 on: Fri, 03 May 2013, 10:28:08 »
I really like mice made by Zowie: http://www.zowiegear.com/ .One of the few "gamer" brands that offer good quality at decent prices. I use their AM mouse which I got after about 3 years with a Razer lachesis
Offline vun
  • Just one more thing
Re: Gaming Mouse
« Reply #11 on: Fri, 03 May 2013, 11:34:42 »
If you're looking for a good mouse for not a lot of cash I can heartily recommend the Logitech G400 and the Razer Abyssus, those are some of best mice on the market and they're also some of the cheapest ones.
Offline inteli722
Re: Gaming Mouse
« Reply #12 on: Fri, 03 May 2013, 11:50:03 »
I can honestly say the opposite. I had a RAT 7, and I really enjoyed it. It worked well, and only failed because of an error on my part (note: do NOT wrap the cable around the mouse). I use higher DPI, so the Z-Axis bug didn't affect me. It felt great.
(hardly)TL;DR: If you use a higher DPI (Don't lift the mouse), then I can highly recommend the RAT 7.
Waiting for: Phantom Plate
Offline audioave10
Re: Gaming Mouse
« Reply #13 on: Sat, 04 May 2013, 10:37:32 »
My industrial hands require a MX 518 which Logitech doesn't make anymore. Keep in mind the size if you order online.
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Re: Gaming Mouse
« Reply #14 on: Sat, 04 May 2013, 12:26:56 »
For many people, the Z-axis bug and the Philips Twin Eye sensor makes the mouse a minefield.  The mouse also has a reputation for dying rather quickly.  It's not uncommon to find people who have gone through 3 and 4 of them.
Offline Grim Fandango
Re: Gaming Mouse
« Reply #15 on: Sun, 05 May 2013, 04:14:09 »
I play on low sensitivity and simply can not use that sensor.
I recommend the Zowie FK as an alternative to the sensei with the same shape. It is driverless and without prediction, acceleration, and its optical sensor tracks well on a lot of surfaces. It also has a very low lift off distance. Though of course, most important thing ( and the reason why mice recommendations are hard to make) is that it fits your grip and anatomy.
I think the G400 is a good suggestion as well. A lot of people like its shape, it is relatively cheap, and it has one of the best sensors on the market. Better than a lot of the laser sensors found in much more expensive flagship models.
Offline frenchie4111
Re: Gaming Mouse
« Reply #16 on: Mon, 06 May 2013, 15:55:26 »
I wish I had known this sooner. I have had the RAT7 for about 10 months now and so far I have had very little problem with it.
Filco MJ2 TKL
Offline GeoTang
Re: Gaming Mouse
« Reply #17 on: Mon, 06 May 2013, 19:11:05 »
http://www.overclock.net/t/854100/gaming-sensor-list
Here's a list of mice that have either the Avago 3800 or Avago 9500 series.
If you are serious, and playing shooters and the like, the 3800 is prob what you should be looking at.
Otherwise, 9500 isn't too bad. It's a ~5% mouse acceleration so a very minor deal.
That list is pretty much all you really need to look up. Just categorize your grip style and go for it.
I personally use the Roccat Savu since I claw.
Offline Flying4Pandas
Re: Gaming Mouse
« Reply #18 on: Wed, 08 May 2013, 11:12:39 »
I play with a Logitech G9. Its a bit of a tricky mouse to get use to with larger hands, but once you've become accustomed to the claw grip style it is amazing. You can change mouse speed on the fly, and even unlock the mouse wheel to freely scroll web pages.
Offline n0rvig
Re: Gaming Mouse
« Reply #19 on: Thu, 09 May 2013, 19:13:36 »
I like my Logitech G7. You might like something similar. However for me, it's more mouse than I need. Next time I think I'll go for something simple.
Offline Creizai
Re: Gaming Mouse
« Reply #20 on: Thu, 09 May 2013, 19:57:29 »
Zowie MiCo is what I use for everything.
I do love me some WMO though
Offline lucifurburch
Re: Gaming Mouse
« Reply #21 on: Sun, 12 May 2013, 18:16:47 »
I know this is a rather unpopular choice but I love my rat 7 and yes I know about the Z-axis bug what most people don't know is the problems are limited to the  version of the rat 7 with the half circle sensor that cyborg made and all of the mad catz versions, the one with full circle sensor made by cyborg works perfectly I've had one now for over three years and it hasn't had any problems at all, that being said I would not recommend buying one unless you check the sensor first which is not likely unless you buy it second hand from e-bay (I bought an extra one from e-bay for my second computer).
Offline missalaire
  • Great Finder of Great Finds
Re: Gaming Mouse
« Reply #22 on: Sun, 12 May 2013, 18:19:54 »
Logitech G9x
Re: Gaming Mouse
« Reply #23 on: Sun, 12 May 2013, 18:22:05 »
I just got a G9X for my home rig and it's amazing. I had a DeathAdder 2013 but it was too big for my hands. At work I use an Abyssus and it's also really nice. I have small hands so I need smaller mice. I palm grip both :D
Re: Gaming Mouse
« Reply #24 on: Sun, 12 May 2013, 18:30:12 »
Mionix Naos. Any of the models are amazing mice.
Offline Patchwrks
Re: Gaming Mouse
« Reply #25 on: Sun, 12 May 2013, 20:11:47 »
G400
(´・ω・`)denko-chan~~~내 스레드
Offline dndlmx
Re: Gaming Mouse
« Reply #26 on: Mon, 13 May 2013, 12:59:05 »
I use a Razer Salmosa. It works fine for my purposes, and can be had for only ~20 USD.
Offline Badwrench
  • ummmm.....I forgot
Re: Gaming Mouse
« Reply #27 on: Mon, 13 May 2013, 19:57:28 »
Love my DA black.  Went through a ton of mice trying to find one for my grip (claw in front, but palm in back). I really liked the Wheel mouse optical by Microsoft, but ended up giving it away when I found a deal on a used Deathadder.  Great feeling mouse.
http://www.ebay.com/itm/Razer-Deathadder-Infrared-Gaming-Mouse-/221226906265?pt=Mice&hash=item338226b299
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Gaming Mouse
« Reply #28 on: Mon, 13 May 2013, 20:51:11 »
Currently use the Sensei but I've been thinking about trying the G700S next.
Offline Spokoman
Re: Gaming Mouse
« Reply #29 on: Thu, 23 May 2013, 09:47:31 »
If you're still looking for a gaming mouse and are on a budget I recommend Anker High Precision Laser Gaming Mouse.
Ducky Shine II Blue LED Brown Switches
CM QF TK Red LED Red Switches
Offline Sorun
  • Chitos
Re: Gaming Mouse
« Reply #30 on: Fri, 31 May 2013, 14:25:32 »
G400 is pretty good for what is essentially a budget mouse, if you want all the bells and whistles of a higher end mouse look into razer or steel series.
Offline Riddixk51PB
Re: Gaming Mouse
« Reply #31 on: Sat, 08 June 2013, 16:03:20 »
LT G400 is discontinued.  G400s is the replacement model.
I am now using the Roccat Kone XTD (Avago 9800), set u back about $90
KBD: CM Storm QuickFire Pro, Cherry MX Brown
Mouse: Roccat Kone XTD (Avago ADNS-9800 High-Performance LaserStream™)
