Author Topic: Realforce board not leveled flat  (Read 1714 times)
Offline simingma
« on: Sat, 04 May 2013, 19:53:49 »
Guys,
I just received my 55g 87u from EK. Everything looked fined but the instant I put it in a flat surface I found its not laying flat. One corner is about 2mm higher, and rattles a lot when typing. This is true for both with feet up and without.
Is this kind of build quality within their specs?
Offline khaangaaroo
Re: Realforce board not leveled flat
« Reply #1 on: Sat, 04 May 2013, 19:58:35 »
Have you tried twisting it into shape? If it's too far twisted to be bent back flat, then you should RMA it.
Offline simingma
« Reply #2 on: Sat, 04 May 2013, 20:01:54 »
No, not tried to twist it hard. Will try that when I get home. I thought EK only does repair so interesting to see what they are gonna do. Thanks
Offline simingma
« Reply #3 on: Sat, 04 May 2013, 21:20:21 »
Twisting worked!  :D
So not only it taps like clay, but also bends like that. lol
Offline MJ45
  • HHKB Pro
« Reply #4 on: Sun, 05 May 2013, 08:53:12 »
Mine was the same I thought "what the ****" but a little twist and the tabs latch clicked it was fine. Maybe some rough handling during shipping or something?
