Author Topic: Keycap puller dimensions  (Read 10130 times)
Offline AGmurdercore
« on: Sun, 05 May 2013, 07:13:32 »
Soo long story short i need a keycap puller but i can not afford to spent like 13-15$ for one + shipping so i will try to make one. Can anybody give me the dimensions of a standart key puller like this one
Thank you in advance!
P.S. I know i can just use paper clip but i want to have one decent looking :)
What the hell am I even doing
Re: Keycap puller dimensions
« Reply #1 on: Sun, 05 May 2013, 08:42:47 »
Numerical dimensions are less useful.
Just gauge it with an actual key. It needs to be "just" large enough to fit around the key, and no larger, or else it will not fit between the next one.
PS - I think that elitekeyboards sell the Leopold one for about $6, and that is my favorite.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
« Reply #2 on: Sun, 05 May 2013, 08:48:50 »
Ah thank you did not think of that about the keycap dimension :D
About the prices - yes they are 5-6$ but i am from Bulgaria so the shipping is at least another 5$ even more, thats why i want to just craft one myself :)
Offline regicide
  • Software developer and Open source hacker
« Reply #3 on: Sun, 05 May 2013, 17:38:40 »
You should be able to guage the size by looking at the keys you will be pulling, hopefully you can see the action required in the following pictures
I have also seen some homemade key cap pullers that appear to be string or possibly cable ties
I cant link the post itself (the link it gives is incorrect), it is a few posts down on this page
https://forum.lowyat.net/topic/2096177/+1260
« Last Edit: Sun, 05 May 2013, 17:40:19 by regicide »
2 Kinesis advantages (MX browns)
Offline Jocelyn
  • 조셀린
« Reply #4 on: Sun, 05 May 2013, 17:40:00 »
Offline linziyi
  • The one with many questions
« Reply #5 on: Sun, 05 May 2013, 17:41:09 »
How do you pull out the longer keys like shift, enter and spacebar?
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline regicide
« Reply #6 on: Sun, 05 May 2013, 17:43:54 »
You have to be careful with those keys as they often have a metal 'stabilizer' bar which could be damaged by just yanking
It is usually a matter of lifting the key up enough to see the stabilizer and then removing the stabilizer often by sliding in a certain direction or pulling it out of the clips (there are a few different mechanisms for stabilizers)
« Last Edit: Sun, 05 May 2013, 17:50:13 by regicide »
Offline Jocelyn
  • 조셀린
« Reply #7 on: Sun, 05 May 2013, 17:47:34 »
Yes, I am grateful for Cherry stabs :)
Lift half off, then insert/wedge something on that side (spudger or whatever) and pull up on the other side with the puller :)
Offline linziyi
« Reply #8 on: Sun, 05 May 2013, 17:53:11 »
But what about the other type of stabilizer (cherry i think?)?
Ducky DK9008G2 Pro
Offline Jocelyn
  • 조셀린
Re: Re: Keycap puller dimensions
« Reply #9 on: Sun, 05 May 2013, 17:58:16 »
Nothing to worry about. Only Co-star stabs are a PITA.
Offline regicide
« Reply #10 on: Sun, 05 May 2013, 17:59:16 »
Cherry stabilizers are pretty easy to deal with as the key has 3 stems rather than 1, so it is generally safe to just pull upwards.
The sliding wire type which are easier to damage (you can't just pull)
Offline linziyi
« Reply #11 on: Sun, 05 May 2013, 18:03:57 »
But how to use the ring style keypuller to get them out?
Ducky DK9008G2 Pro
Offline regicide
« Reply #12 on: Sun, 05 May 2013, 18:09:10 »
You first pull the key up a bit to expose the wire (and pull the key off the stem) then slide the hoops left and right to remove them off the wires, the first slide will often require a bit of force.
To put them back on you do the inverse, slide one side on, slide on the other (this will require a bit of force) and then push the key back on to the stem.
EDIT: searching should be able to find entire threads on the subject, goodluck and don't blame me if/when you break a key  ;D
« Last Edit: Sun, 05 May 2013, 18:16:25 by regicide »
Offline linziyi
« Reply #13 on: Sun, 05 May 2013, 18:13:19 »
TY!
Ducky DK9008G2 Pro
