Author Topic: Worth picking up? WEY Banking Double Shot Keytop Mechanical Keyboard  (Read 2352 times)
Re: Worth picking up? WEY Banking Double Shot Keytop Mechanical Keyboard
« Reply #1 on: Sun, 05 May 2013, 11:15:15 »
You won't be able to use it. If you want to spend hours desoldering the switches then it might be worth it, but still £80 is a bit much.
Offline Chanc3
« Reply #2 on: Sun, 05 May 2013, 11:17:07 »
Ah thought it could be a pita, thanks for heads up.
« Reply #3 on: Sun, 05 May 2013, 11:52:01 »
If it is re-listed at a lower price, it may be worth it for the switches and keys alone - that is a lot of "different" double-shots in some "interesting" colours ......
- Plato
Offline gnubag
« Reply #4 on: Sun, 05 May 2013, 12:17:43 »
also windowed f-keys
Offline berserkfan
« Reply #5 on: Sun, 05 May 2013, 13:29:00 »
wow. I really wish I had a keyboard like that. Windowed keys with LEDs!
« Reply #6 on: Sun, 05 May 2013, 14:05:36 »
I enjoy keyboards with lots of function keys, so I've always wanted to get a WEY 'board. I'd wire everything up to a teensy++ though so I can use it.
