Author Topic: Minimum word length in search  (Read 7671 times)
Offline lowpoly
« on: Thu, 12 June 2008, 03:05:47 »
Hi iMav,
right now the minimum word length in search is 4. Can this be reduced?
Thanks.
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Thu, 12 June 2008, 04:25:07 »
Quote from: sofa king;5369
Yes, it can.  Did you have a lower number you'd like to request?  Or were you just curious?  :)
Offline lowpoly
« Reply #2 on: Thu, 12 June 2008, 05:08:08 »
I always bump into that limitation during search. Many model numbers are just three digits like G80, M15, etc. Some are just 2, for ex. M2.
So, 2 would be fine, I guess.
Thanks.
Offline IBI
« Reply #3 on: Thu, 12 June 2008, 06:30:43 »
1 might be best so "Model M" is allowed.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline iMav
« Reply #4 on: Thu, 12 June 2008, 08:12:43 »
Enjoy!
(I also made a change that should make xsphat quite pleased...I'll let him figure out what it is)
Offline lowpoly
« Reply #5 on: Thu, 12 June 2008, 09:01:45 »
Thank you!
(off to search...)
Edit: looks like it doesn't work, for ex. 7g gives 0 hits. Maybe a re-index is neccessary?
Offline iMav
« Reply #6 on: Thu, 12 June 2008, 09:25:23 »
Quote from: sofa king;5383
Doah!  Even though I changed vB's minimum search length, I needed to reconfigure mysql since I use the mysql fulltext search.
Should be good to go now.
Offline iMav
« Reply #7 on: Thu, 12 June 2008, 09:32:24 »
Another comment on searching.
If you click on "Search" on the top navigation bar, there is the option to search via Google.  This is not a site-specific search, but a full google search.  However, if you preface your search with "site:geekhack.org", you'll get results back just for this site.
The results are also wrapped in the geekhack template, so it is kinda cool.
For instance, try using the google search and put in the following:
Offline lowpoly
« Reply #8 on: Thu, 12 June 2008, 10:21:38 »
Works now, thank you.
And I finally found the thread I've been looking for.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #9 on: Fri, 13 June 2008, 00:14:59 »
Quote from: iMav;5381
k
Offline xsphat
  • Enlightened
« Reply #10 on: Fri, 13 June 2008, 00:15:31 »
Offline ashort
  • Hoosier Daddy
    • http://andrew.wingedwheel.net
« Reply #11 on: Fri, 13 June 2008, 06:09:26 »
Hey!
Andrew
{ KBC Poker - brown | Filco Majestouch - brown | Dell AT101W | Cherry G84-4100 }
