Author Topic: Painted my keycaps (pic added)  (Read 2795 times)
Offline kaotikb
« on: Sun, 05 May 2013, 21:25:58 »
I painted my key caps with Krylon spray paint for plastics. It came out pretty well considering that i didn't really do any prep work. I just wiped down the caps with some isopropyl alcohol and away i went. I probably should have used the matte paint instead of the glossy ,but oh well.
« Last Edit: Sun, 05 May 2013, 21:33:58 by kaotikb »
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline esoomenona
  • Gnillort?
Re: Painted my keycaps (pic added)
« Reply #1 on: Mon, 06 May 2013, 09:23:51 »
Are they sticky as you type?
Offline okooko
  • afk.
« Reply #2 on: Mon, 06 May 2013, 09:34:14 »
not sure if its just the photo but i can see fingerprints on the 't' and 'y' buttons.
Offline badcop
  • thorpe thocking master race
« Reply #3 on: Mon, 06 May 2013, 09:41:24 »
did you scuff them up at all?  i've never had any lucky painting plastics without any prep  :(
Offline kaotikb
« Reply #4 on: Mon, 06 May 2013, 12:05:09 »
Yeah they were still sticky when I put them on. So the t, y and wasd have prints on them. I might fix them up when I have time.  Red ones took the longest to dry. I just wanted to see how it would turn out. If I did some prep work I am sure it would be better.
