Poll
What should the maximum Avatar size be?
50x50 pixels
3 (3.2%)
100x100 pixels (previous limit)
29 (31.2%)
150x150 pixels (current limit)
31 (33.3%)
184x184 pixels
11 (11.8%)
Even larger
7 (7.5%)
Don't care
8 (8.6%)
120x120 pixels
3 (3.2%)
Even smaller
1 (1.1%)
Total Members Voted: 93
Author Topic: Avatar size  (Read 119824 times)
Offline Soarer
Re: Avatar size
« Reply #150 on: Tue, 14 May 2013, 15:57:29 »
lmao The_Ed's avatar looks so much worse now hahaha
Worse?... Do explain.
It is simply a sucky avatar...  get some anti-aliasing, or go full old-school pixels. Currently it's neither. And really does not use the extra pixels you wanted so badly well at all.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Avatar size
« Reply #151 on: Tue, 14 May 2013, 15:58:11 »
burn man. BURN
Offline Soarer
Re: Avatar size
« Reply #152 on: Tue, 14 May 2013, 16:03:48 »
No one seemed to complain about the margin changes.  Avatar size limit is now 150x150 pixels.
You miss my complaining? OK. It sucks, with a massive dead gap for most people (i.e. with 100px avatars and sensible name length).
The one upside is that people's custom texts and locations now wrap less.
TBH, once you started to seem keen on making the change, I redirected my thoughts to Greasemonkey.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: Avatar size
« Reply #153 on: Tue, 14 May 2013, 16:03:59 »
It's the image uploading that borks it...
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline Soarer
Re: Avatar size
« Reply #154 on: Tue, 14 May 2013, 16:08:26 »
The 184 pixel version in the first post as well?
Offline The_Ed
Re: Avatar size
« Reply #155 on: Tue, 14 May 2013, 16:11:27 »
Yes, Imgur likes to do that too...
R.I.P.ster
Offline Soarer
Re: Avatar size
« Reply #156 on: Tue, 14 May 2013, 16:14:17 »
ROFL... how many other sites can you blame for ruining your amazing avatar :p
What is is meant to be like anyway? Seems to have an anti-aliased outside, and a blocky inside  :-\
Offline The_Ed
Re: Avatar size
« Reply #157 on: Tue, 14 May 2013, 16:15:47 »
You have to pay for Imgur to not compress your pics...
R.I.P.ster
Offline E TwentyNine
    • Some of My Keyboards
Re: Avatar size
« Reply #158 on: Tue, 14 May 2013, 16:18:51 »
Upload it to min.us then, no compression there.
Offline Soarer
Re: Avatar size
« Reply #159 on: Tue, 14 May 2013, 16:23:31 »
Does the bug here affect an avatar image if you resize it before uploading? Does it affect attachments?
Offline esoomenona
  • Gnillort?
Re: Avatar size
« Reply #160 on: Tue, 14 May 2013, 16:26:12 »
Yes to your first question. That's pretty much the only qualm I had with avatars. rknize mentioned he would look into that. Not sure about the second.
Offline baldgye
  • Will Smith Disciple
Re: Avatar size
« Reply #161 on: Tue, 14 May 2013, 16:32:31 »
My fairly detailed 100x100 avatar still looks pretty good to me....
Offline Soarer
Re: Avatar size
« Reply #162 on: Tue, 14 May 2013, 16:33:47 »
Yeah, I think The_Ed's is just a case of GIGO  :))
Offline The_Ed
Re: Avatar size
« Reply #163 on: Tue, 14 May 2013, 16:37:29 »
It's thin curved white lines... They don't do well with compression... GIGO used to describe an avatar instead of code, that's a first. You sure seem bent on dissing my avatar for some unknown to me reason.
R.I.P.ster
Offline Soarer
Re: Avatar size
« Reply #164 on: Tue, 14 May 2013, 16:41:04 »
Well you're the one that wanted them so badly... you could at least make good use of the extra size!
I'm not used to GIGO describing code, more to describe processing.
Offline Glissant
Re: Avatar size
« Reply #165 on: Tue, 14 May 2013, 16:41:50 »
Mmmm 150x150 mmmm. Exactly what I was looking for. Hope it sticks. I don't like that my avatar's colors are different from the original, but meh.. can't have everything :).
Offline The_Ed
Re: Avatar size
« Reply #166 on: Tue, 14 May 2013, 16:44:08 »
If people want it to stick they need to keep voting for it as the poll is open indefinitely.
R.I.P.ster
Re: Avatar size
« Reply #167 on: Tue, 14 May 2013, 16:51:38 »
They do fine with compression if you create them correctly.
Feel free to use it while I figure out a new and improved 150x150 avatar.
« Last Edit: Tue, 14 May 2013, 16:53:24 by E TwentyNine »
Offline aggiejy
Re: Avatar size
« Reply #168 on: Tue, 14 May 2013, 19:12:56 »
I was about to say... resizing via any automated software will give you strange behavior for an image with lines and such.  But you can make a decent image at any size.  Of all avatars to benefit from a larger size, I don't think this would be one.  (But, I don't even know what it is or what it means... so whatever.)
Offline aggiejy
Re: Avatar size
« Reply #169 on: Tue, 14 May 2013, 19:31:07 »
What does the avatar mean anyway?  Seems like I've seen it before, but can't put my finger on it.  The feeling I get is something like...
« Last Edit: Tue, 14 May 2013, 19:36:54 by aggiejy »
Offline esoomenona
  • Gnillort?
Re: Avatar size
« Reply #170 on: Tue, 14 May 2013, 19:49:49 »
Ask him if it's from Deathly Hallows.
Offline Soarer
Re: Avatar size
« Reply #171 on: Tue, 14 May 2013, 19:53:54 »
Maybe this is The_Ed...
Offline The_Ed
Re: Avatar size
« Reply #172 on: Tue, 14 May 2013, 20:01:54 »
* SmallFry makes The_Ed a wiki account and posts a large Deathly Hallows insignia to his Wiki Page.
It took me a few hours in gimp... (Yeah... I still don't really know how to use gimp, but whenever I need a different sized avatar I can make it from the source file. Which means I'm not totally incompetent...)
It is a symbol that I made MANY years ago (except that the avatar version is missing the infinity symbol underneath. With how small avatars are often limited to I figured it would be best to just chop that off.) I still remember when 'Harry Potter and the Deathly Hallows' came out... The symbol for the deathly hallows was very similar... Though I suppose there were quite a few other's that were similar long before then, I never really noticed until after deathly hallows came out...
Mine
Deathly Hallows
                 (Imagine the infinity symbol here)
It's NOT the ****ing deathly hallows!
R.I.P.ster
Offline Soarer
Re: Avatar size
« Reply #173 on: Tue, 14 May 2013, 20:04:38 »
Seriously though, it's a hamster wheel. Can't see it as anything else now.
Offline aggiejy
Re: Avatar size
« Reply #174 on: Tue, 14 May 2013, 20:11:34 »
Less evil versions, and works on all backgrounds.
« Last Edit: Tue, 14 May 2013, 20:16:23 by aggiejy »
Offline The_Ed
Re: Avatar size
« Reply #175 on: Tue, 14 May 2013, 20:18:00 »
Wrong - The infinity symbol is the entire width of the triangle, and the same thickness of line. Which means a tall and skinny avatar if you don't cut off the infinity symbol. I will probably redo it at some point in thicker lines so as to minimize the visual jagginess in a compressed avatar.
R.I.P.ster
Offline aggiejy
Re: Avatar size
« Reply #176 on: Tue, 14 May 2013, 20:28:48 »
Yeah, that's some weird ****.  I give up.
Offline rknize
    • metaruss
Re: Avatar size
« Reply #177 on: Tue, 14 May 2013, 20:32:52 »
It's an amusement park with a Ferris wheel and a go-kart track.
Russ
Offline Soarer
Re: Avatar size
« Reply #178 on: Tue, 14 May 2013, 20:38:21 »
Infinity? That's just a twisted hamster.
Re: Avatar size
« Reply #179 on: Tue, 14 May 2013, 20:51:47 »
I think I found my new avatar.
And would you look at all the compression based jagginess?
Offline keymaster
  • Topre Revolution Theorist
Re: Avatar size
« Reply #180 on: Tue, 14 May 2013, 22:33:31 »
It has begun.
Offline The_Ed
Re: Avatar size
« Reply #181 on: Tue, 14 May 2013, 22:45:11 »
It has begun.
What has? The baconing?
R.I.P.ster
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Avatar size
« Reply #182 on: Tue, 14 May 2013, 23:34:05 »
What's with the huge deathly hallows logo Ed?
« Last Edit: Tue, 14 May 2013, 23:47:31 by JesuswasaZombie »
Offline mkawa
Re: Avatar size
« Reply #183 on: Tue, 14 May 2013, 23:54:56 »
8bit hamster wheel = win.
Offline The_Ed
Re: Avatar size
« Reply #184 on: Wed, 15 May 2013, 00:06:06 »
I have had many pet rats, and my Dad named the squirrel that stalks him "Darth Squirrel". So if it is an animal wheel, it is anything but a hamster wheel. Hämsterviel!
Besides, it predates the rats, darth squirrel, and the harry potter deathly hallows.
R.I.P.ster
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Avatar size
« Reply #185 on: Wed, 15 May 2013, 01:30:53 »
I hope 184 wins! I'm currently loving the huge avatars that fit perfectly on the side. The bigger the better to personalize :P
Offline The_Beast
  • I like wood ಠ_๏
Re: Avatar size
« Reply #186 on: Wed, 15 May 2013, 01:36:31 »
Not really liking the bigger avatars, it's kinda distracting
Offline Jocelyn
  • 조셀린
Re: Avatar size
« Reply #187 on: Wed, 15 May 2013, 01:37:59 »
I finally voted  :p
Offline VesperSAINT
  • vpsert
  • #CustomKorean
Re: Avatar size
« Reply #188 on: Wed, 15 May 2013, 01:38:36 »
I'm sure you'll get used to it, and then you can show off the detail of your beautiful wrist rest (is it a wrist rest?) through your avatar :P
I finally voted  :p
Yay! I think I can guess what you voted :P
« Last Edit: Wed, 15 May 2013, 01:40:15 by VesperSAINT »
Offline The_Ed
Re: Avatar size
« Reply #189 on: Wed, 15 May 2013, 02:13:23 »
Can the poll options be changed to reflect what is current?
100x100 pixels (current limit) -> (previous limit)
150x150 pixels (fits the current layout) -> (current limit)
R.I.P.ster
Offline Jocelyn
  • 조셀린
Re: Avatar size
« Reply #190 on: Wed, 15 May 2013, 02:15:05 »
Haha you thought right :)
Lock thread, redo poll with only those two options? :P
Offline The_Ed
Re: Avatar size
« Reply #191 on: Wed, 15 May 2013, 02:16:26 »
Not my poll (though I was the one who started the lobby and threads), and that is too restrictive of options.
R.I.P.ster
Offline Jocelyn
  • 조셀린
Re: Avatar size
« Reply #192 on: Wed, 15 May 2013, 02:17:24 »
Oh I totally misunderstood your request. Sorry :)
Offline The_Ed
Re: Avatar size
« Reply #193 on: Wed, 15 May 2013, 02:21:37 »
It's funny that with only a 50 pixel size increase I can now see that there are 2 women in your avatar. I didn't notice that before...
R.I.P.ster
Offline Soarer
Re: Avatar size
« Reply #194 on: Wed, 15 May 2013, 02:29:33 »
Why the margin change anyway? 150x150 was supposed to "fit the current layout".
Offline The_Ed
Re: Avatar size
« Reply #195 on: Wed, 15 May 2013, 02:32:10 »
Wow...100x100 has nearly caught up to 150x150.  I've deployed the code changes to support 150x150.  The additional space in the left margin should be apparent.  I recovered some dead space in a few other spots as well, so the margin increase is not 1:1 with the 150px width.
Avatar limit is still 100x100.  Let's see where we are at the end of the day.
R.I.P.ster
Offline Soarer
Re: Avatar size
« Reply #196 on: Wed, 15 May 2013, 02:34:11 »
Exactly... "the margin increase" does not tally with "fits the current layout".  :rolleyes:
« Last Edit: Wed, 15 May 2013, 02:38:32 by Soarer »
Offline rknize
    • metaruss
Re: Avatar size
« Reply #197 on: Wed, 15 May 2013, 02:37:10 »
I meant that it did not interfere with the header rendering the way larger ones do.  The margin did have to be tweaked, but not by much.
Russ
Offline Soarer
Re: Avatar size
« Reply #198 on: Wed, 15 May 2013, 02:39:07 »
The peoples was duped! But not by much.  :))
Offline The_Ed
Re: Avatar size
« Reply #199 on: Wed, 15 May 2013, 02:41:43 »
I would bet that >95% of the people here don't even notice the 50 pixel increase. Of the remaining <5% the majority prefer larger.
R.I.P.ster
