Author Topic: Delete  (Read 3292 times)
Offline Dreamre
    • kbdlife
Delete
« on: Mon, 06 May 2013, 20:05:17 »
Delete...
« Last Edit: Tue, 23 May 2017, 15:51:59 by Dreamre »
Offline Permeability
Re: Defect on Filco MJ2
« Reply #1 on: Mon, 06 May 2013, 20:28:09 »
I think all Filcos have that. Mine do. It's probably part of the plate design
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
« Reply #2 on: Mon, 06 May 2013, 20:29:17 »
Not a defect. They all have them and even if it were a defect it wouldn't be a reason to RMA.
Offline dante
« Reply #3 on: Mon, 06 May 2013, 20:31:57 »
It's the secret sauce to Filco's ping
Offline Dreamre
    • kbdlife
« Reply #4 on: Mon, 06 May 2013, 20:51:54 »
Ah okay...LOL.
Thanks for the clarification :D.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #5 on: Mon, 06 May 2013, 21:01:35 »
Offline Rule16
  • R.I.P. SmallFry
« Reply #6 on: Mon, 06 May 2013, 21:10:22 »
Wait... You sent back a board because it had a screw in the plate...? Seriously? You shouldnt get a Realforce board; you'll **** yourself when you see that plate.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline PointyFox
« Reply #7 on: Mon, 06 May 2013, 21:12:02 »
..and I thought I was fussy.
Offline Rule16
  • R.I.P. SmallFry
« Reply #8 on: Mon, 06 May 2013, 21:18:14 »
I know... Da **** is dis?
Dvorak Only Zone
Offline Dreamre
    • kbdlife
« Reply #9 on: Mon, 06 May 2013, 22:06:31 »
The first one I sent was due to faulty switches :(.
@PointyFox, yup...fussy to the next level :D.
Offline PointyFox
« Reply #10 on: Mon, 06 May 2013, 22:07:05 »
"Dear Diatec,
Your QC is horrible.  I am returning this extremely defective keyboard because I found something on an inside surface that I don't think should be there (see attached AFM image).
Offline Rule16
  • R.I.P. SmallFry
« Reply #11 on: Tue, 07 May 2013, 05:15:36 »
"Dear Diatec,
Oh dayum. Now Ive gone and make my self look stupid, seriously does look like a screw in the first pic... How were the switches faulty? Non clicky blues? Sorry for your bad luck :(
Dvorak Only Zone
Offline Grim Fandango
« Reply #12 on: Tue, 07 May 2013, 05:18:42 »
every now and again we all fail to control our OCD
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #13 on: Tue, 07 May 2013, 05:23:11 »
This, I can agree with frequently.
Offline WhiteFireDragon
    • youtube
« Reply #14 on: Tue, 07 May 2013, 05:30:39 »
lol OP you were about to RMA for the 2nd time for that bump? That's where the spacer screws into. The hex spacer is used to separate space between the plate and PCB, and also to screw the PCB and plate together. You can't see the hex part because it's on the other side of the plate.
All recently produced Filcos have that. The old ones didn't.
