Author Topic: PBT dyesub 104/105 set ROUND 2 (complete)  (Read 348445 times)
Offline baldgye
  • Will Smith Disciple
Re: PBT dyesub 104/105 set ROUND 2
« Reply #450 on: Thu, 06 June 2013, 10:51:54 »
if the ISO set dsnt go through I'll go for the miami US and if that dsnt go through then the limited thing
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #451 on: Thu, 06 June 2013, 10:54:47 »
Will start dropping off choices around the 20th or so, and give chance to switch options for those that wish to. Depending on how things go this could end up being novelty keys only, and revisit sets later.
Offline LechnerDE
« Reply #452 on: Thu, 06 June 2013, 11:01:14 »
This would be the case if we don't reach the 300 sets total right? So even if Miami Ltd gets 50 orders it won't happen?
« Reply #453 on: Thu, 06 June 2013, 11:03:37 »
I was wondering about Miami Ltd too.  I think it was said that the keys are in hand, so maybe (hopefully) it's different?
« Reply #454 on: Thu, 06 June 2013, 11:07:31 »
Need 20 or more, can do Miami on all white key since sets still on hand from last time. It's OK. Maybe some other can do too, depend on if imsto want to make less with 2tone or not. We will just have to see what it is looking like in couple week.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #455 on: Thu, 06 June 2013, 12:35:09 »
Two questions before I place an order:
#1 Is there a status page somewhere? (I admit I didn't read all 16 pages of posts.)
#2 Are BLANK R4 1.25 mods available?  I see them in some of the sets, but not individually.
 - Ron | samwisekoi
« Reply #456 on: Fri, 07 June 2013, 06:13:04 »
These sets are compatible with any MX keyboard with 1.25 modifier 104/105, 87/88, 61/62 keys except spacebars on Leopold, Keycool, Plum.
Just to mention that the space bar on the KeyCool 87 is the same as that on Filco i.e. standard.
This post has the pics: http://geekhack.org/index.php?topic=43143.msg920703#msg920703
I also tried the Filco space bar on the KeyCool and the KeyCool space bar on the QFR - both fitted perfectly.
Offline Moosecraft
  • HHKB Pro
« Reply #457 on: Fri, 07 June 2013, 18:10:17 »
****, I'm so mad that they don't have ISO enters..
Offline Acanthophis
« Reply #458 on: Fri, 07 June 2013, 19:37:52 »
I'm more mad they don't have 1.5u, 1.75u and 7u molds :/
« Reply #459 on: Fri, 07 June 2013, 19:54:50 »
If only could figure out which is the source from Noppoo, Neo, Plum keycap we could also get the 1.5 and 1.75 sorted.
There is no status page.
I think I will stick to what individual caps are listed now this time. Will look into getting something co-ordination with imsto for a more varied single cap buy a bit later on.
I didn't realize Keycool changed that. When they came out they were exactly like Leopold. I will try and remember that there is no problem there now.
Offline LechnerDE
« Reply #460 on: Mon, 10 June 2013, 04:45:34 »
No posts for 3 days in this thread :(
Come on people, order some sets!!
 :p
Offline UniClown
« Reply #461 on: Mon, 10 June 2013, 20:22:08 »
Are the E row cherry keys going to be on a white background or on a biege background?
« Reply #462 on: Mon, 10 June 2013, 20:30:02 »
Sorry I thought I posted about that. Single key can be on blue/light grey/medium grey/white. I will assume white unless told otherwise.
Offline UniClown
« Reply #463 on: Mon, 10 June 2013, 20:51:34 »
No biege :(  Thanks for the quick response.
Offline Halvar
« Reply #464 on: Tue, 11 June 2013, 01:33:50 »
So I guess blue means the color of the startcraft set, and white the white of the white/beige sets, right?
What is light grey and what is medium grey?
Is medium grey the color of the Diablo set? Or is medium grey = beige?
And light grey would be the modern Cherry "hellgrau"?
« Reply #465 on: Tue, 11 June 2013, 07:49:15 »
Blue = starcraft, light grey = beige (I think, I will clarify with imsto), medium grey = diablo, white = same color as letter keys it's same off white color used in both all 'white' and 'white'/beige sets.
Offline rindorbrot
« Reply #466 on: Tue, 11 June 2013, 12:29:14 »
I really hope the single keys will be beige
Offline UniClown
« Reply #467 on: Tue, 11 June 2013, 13:58:50 »
I want to go all out and have all my F keys be cherry logos.
Offline Moosecraft
  • HHKB Pro
« Reply #468 on: Tue, 11 June 2013, 15:12:45 »
Ivan
Do you have any real life pictures of the windows keys for the diablo set?
Offline Latin00032
« Reply #469 on: Tue, 11 June 2013, 15:49:39 »
So wait.
Are these sets just white and beige? Or, are any of these sets light grey and medium grey?
I thought all these sets were white and grey.
Offline Photoelectric
« Reply #470 on: Tue, 11 June 2013, 16:04:01 »
Look at the first post--specifically the bottom two full sets.
Offline bazemk1979
« Reply #471 on: Tue, 11 June 2013, 18:07:05 »
going to jump on the Trix full board, cant afford the full set and RGB, sorry Ivan :(
Offline UniClown
« Reply #472 on: Wed, 12 June 2013, 14:49:18 »
Please get back to us with what Imsto says.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #473 on: Thu, 13 June 2013, 16:16:14 »
Please cancel my order. Thanks.
« Reply #474 on: Sat, 15 June 2013, 16:16:46 »
OK, so this is what is NOT in danger of being deleted as options:
BLANK
MIAMI LTD
URAL
IRISH US INTL
RED US
BLACK US
Even those listed above still have not all reached the 20 minimum. I would like to see at least those make the 20 so those can be run. Either way, if sets can't make it I will still try to go ahead with the individual keys and RGB modifiers sets.
Offline UniClown
« Reply #475 on: Sat, 15 June 2013, 16:42:02 »
BLANK
MIAMI LTD
URAL
IRISH US INTL
RED US
BLACK US
Thanks.
BTW: Photobucket has stopped showing the images in the first post because it is using too much bandwidth.
Offline Jocelyn
  • 조셀린
« Reply #476 on: Sat, 15 June 2013, 19:18:38 »
BLANK
MIAMI LTD
URAL
IRISH US INTL
RED US
BLACK US
That should read individual keys, RGB modifier sets, and MIAMI LTD, right? I'm asking because I thought Imsto already had 50 write sets on hand.
Edit - Never mind, I guess MIAMI LTD hasn't necessarily hit 20 yet.
« Reply #477 on: Sat, 15 June 2013, 20:50:12 »
Right it still need at least 20 set for set up to make it worth their time.
Thanks Photoelectric for mirroring the layout images because photobucket sucks. I need to get some other account another place one of these days when I am not too lazy to do so.
« Reply #478 on: Sat, 15 June 2013, 21:49:20 »
Sure--this Group Buy needs more exposure for more awesome keycaps!
Here is my current plan for 2 TKL keyboards :)
Offline lespaul
« Reply #479 on: Sun, 16 June 2013, 10:24:27 »
Is there any status page?
How can i check my order?
« Reply #480 on: Sun, 16 June 2013, 10:51:30 »
lespaul, I show you down for 1 Black US, 1 Blank.
Offline Latin00032
« Reply #481 on: Mon, 17 June 2013, 11:21:08 »
I was about to fill the order form in for a hollow set. Should I just go for one of the ones not in danger of being canceled?
« Reply #482 on: Mon, 17 June 2013, 11:27:02 »
Half a month ago there was only 1 order for the Hollow set.  Not sure about now, but I'd go for a different set in terms of likelihood of reaching MOQ.
The Hollow set is definitely very cool.  Perhaps the numbers have changed.
« Last Edit: Mon, 17 June 2013, 11:28:37 by Photoelectric »
Offline iAmAhab
  • Established member
« Reply #483 on: Mon, 17 June 2013, 11:33:25 »
My dream of a two tone nordic iso is dying!
Offline Latin00032
« Reply #484 on: Mon, 17 June 2013, 13:53:36 »
It's cool. It's minimalistic. Shows just enough info. It removes the shift type information but isn't overly simple where there is no text whatsoever.
Offline Mysteric
  • Formerly 'Mackem'
« Reply #485 on: Mon, 17 June 2013, 15:57:19 »
Is blank ISO an option at all?
Offline lespaul
« Reply #486 on: Tue, 18 June 2013, 21:41:21 »
IvanIvanovich, If e-mail address is used for paypal, I wanna change my e-mail assress.
I sent you message
« Last Edit: Wed, 19 June 2013, 03:36:08 by lespaul »
« Reply #487 on: Tue, 18 June 2013, 22:37:30 »
x@y.z -> x@y.z (my paypal account)
Er, strongly suggest you remove the email address from the post and send it via PM.
Lotsa web scrapers out there will grab your email address otherwise.
Offline bardomudo
« Reply #488 on: Tue, 18 June 2013, 22:45:29 »
So, have the invoices been sent yet? Do I have to wait until after June 30?
Offline LechnerDE
« Reply #489 on: Wed, 19 June 2013, 00:49:01 »
No, the invoices haven't been sent out yet. Right now most sets haven't reach MOQ, so it is totally unclear whether your oder will go trough.
Ivan will soon decide which sets will be dropped. Maybe the GB will be extended. We'll see :)
Offline lespaul
« Reply #490 on: Wed, 19 June 2013, 03:35:23 »
ah ok thanx
« Reply #491 on: Wed, 19 June 2013, 08:50:13 »
Right, no invoicing until after order close. imsto already order the white/beige so they are on hand. This means we just need to reach the 20 minimum for each style for that option to happen now. So at least some sets will make it.
Here are the different color keys for singles available. Seems that only blue may be available for 1.25 currently. I am trying to see what it takes quantity to order light grey 1.25 keys from the factory.
[edit] So... factory wants order for 10,000 key for beige 1.25 LOL so it looks like only blue it is. I will assume many will be cancelled. Sorry.
« Last Edit: Wed, 19 June 2013, 09:52:13 by IvanIvanovich »
Offline ilezia
« Reply #492 on: Wed, 19 June 2013, 14:40:34 »
Ivan could you give an order count right now please? How are the red's doing?
Thanks
« Reply #493 on: Wed, 19 June 2013, 15:01:39 »
I'm up to my eyes in GMK stuff right at the minute. I will have a look later on.
Offline asura
  • not a duck
« Reply #494 on: Wed, 19 June 2013, 15:02:59 »
Filled a swimming pool and dived in did we?  :))
« Reply #495 on: Wed, 19 June 2013, 15:08:34 »
Paw keys available as part of the set?
Please?? :)
« Reply #496 on: Wed, 19 June 2013, 15:20:41 »
Was just what imsto happened to take photo of to show all the keycap colors. I suppose you can buy them from imsto if you like those.
Offline rindorbrot
« Reply #497 on: Wed, 19 June 2013, 16:21:39 »
How can we choose the color for the single keys? I guess the second key with the red paw on it should be the same grey as the modifiers, or is it the rightmost key?
« Reply #498 on: Wed, 19 June 2013, 16:24:56 »
I just put the colors in parentheses in my order.  Like "1 E (white)"
Offline UniClown
« Reply #499 on: Thu, 20 June 2013, 17:36:25 »
Thanks Ivan!
