Author Topic: PBT dyesub 104/105 set ROUND 2 (complete)  (Read 348430 times)
Offline swill
  • builder & enabler
    • swillkb.com
Re: PBT dyesub 104/105 set ROUND 2 (packing)
« Reply #900 on: Sun, 03 November 2013, 20:04:05 »
Any advice on finding a fulltouch caps lock in the same color? Would WASD's "dark grey" match?
I don't think wasd does cherry profile, do they?  So even if the cap color matches, I doubt it would be a good solution.
Oh wow, haha, in my ignorance I didn't realize what "Cherry profile" meant when ordering these.
Well you got lucky and got good quality caps.  :)  Now you can compare and see which profile you prefer.  I prefer cherry profile and I am currently typing on caps which are probably from the same mould as this GB.  They are my daily drivers...
Offline phoenix1234
« Reply #901 on: Sun, 03 November 2013, 21:30:12 »
My suggestion is to mod the stem to centre as I did for my imsto set.
It looks ugly because I use resin glue to mod.
The glue is very strong to keep the stem on pbt plastic.
However, in the end, it works perfectly  :thumb:
I like linear switches
Offline phoenix1234
« Reply #902 on: Sun, 03 November 2013, 21:33:35 »
I'm still waiting for my blue set from Ivan and I could mod the centre stepped Caps lock again.
« Last Edit: Sun, 03 November 2013, 22:00:15 by phoenix1234 »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #903 on: Sun, 03 November 2013, 21:55:28 »
why are you modding the center caps lock?
Offline phoenix1234
« Reply #904 on: Sun, 03 November 2013, 21:59:48 »
Sorry, I mean to mod the off-centre stepped caps lock to become centre steppted caps lock as I already did :
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #905 on: Sun, 03 November 2013, 22:06:57 »
Oh, I understand...  I see it now when I look at your picture, but I didn't see the level change initially.  Looks pretty good.  does it feel alright?  how did you clip the stem off?
Offline phoenix1234
« Reply #906 on: Sun, 03 November 2013, 22:26:07 »
Ok, first I use Dremel machine to gradually grind the stem off.
After the original stem was off and destroyed, I used a donor keycap that I had from Taobao, cut it and grind it until I had a balance stem.
Next, I use A-B resin glue to glue the new stem and the pbt caps lock together.
This is the hardest step because making the stem to be centred requires some efforts of measurement and adjustment. For me, I need to lose 2 donor keycaps to make it really works.
After all, the feeling is great. I will take the picture of the keyboard later but for me the position fits nicely with ASD row.
Sorry for potato pic  ;D
« Last Edit: Mon, 04 November 2013, 01:39:40 by phoenix1234 »
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #907 on: Sun, 03 November 2013, 22:35:18 »
Pretty disappointed about the capslock color issue... is there plans to remedy this in the future still?
Offline LechnerDE
« Reply #908 on: Mon, 04 November 2013, 01:26:43 »
Yeah, I feel you.
I ordered 3 different sets, but I don't think I will ever use them with this odd capslock key :(
Maybe Ivan can arrange something with IMSTO and let him produce replacement keys. He could combine it with his current Novelty Key group buy for example.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #909 on: Mon, 04 November 2013, 09:48:05 »
I was hoping I could do that, but sadly the factory that make the keycap don't want to make it easy. They want to enforce 300 MOQ to run that key group mold in beige/grey :( so it looks like there is nothing I can do about it this time.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #910 on: Mon, 04 November 2013, 09:57:26 »
The set you linked is my daily driver.  The color of the caps lock bugged me for about 3 days.  Now I could care less...  Hopefully you will be happy enough with the way the set feels to not care about that minor detail.
Offline JPG
  • Model F is my new passion!
« Reply #911 on: Mon, 04 November 2013, 10:20:55 »
Sad. Very sad ...
Offline Photoelectric
« Reply #912 on: Mon, 04 November 2013, 10:25:55 »
Solution: RIT dye.  Or side-stemmed Caps Lock switch placement.
Offline JPG
« Reply #913 on: Mon, 04 November 2013, 10:32:21 »
Or we find a way to reach the 300 moq. For 1 key, I would probably be willing to buy 2-3 to reach moq even if I only need 1, depending on price. Even if only for blank. 300 is a lot for a full set, but for 1 key it's much less. I don't know what are the volumes for the last GB, but maybe we could make an IC/poll to see if we could get this number.
Offline esoomenona
  • Gnillort?
« Reply #914 on: Mon, 04 November 2013, 10:44:21 »
That company is very stubborn... they never want to do anything.
Looks like its time for you guys to start modding. As a plus, the stepped caps looks nicer.
Offline JPG
« Reply #915 on: Mon, 04 November 2013, 10:49:03 »
I would be happy if the stepped capslock was center stemmed, but it's not (and if I needed an offset stem I would be happy to have it). And if I ever tried to cut the stem and glue it it would be an utter failure, of that I am sure.
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #916 on: Mon, 04 November 2013, 10:59:40 »
le sigh, shouldn't be necessary to mod/dye/buy something that was sold/marketed as is
/rant, note: not directed to Ivan at all, always appreciative of all your hard work in organizing these GBs
« Reply #917 on: Mon, 04 November 2013, 11:10:31 »
Yeah... I get real frustrated with these keycap manufacturers and their stubborn ways. But, they know they essentially have a monopoly (well there is also BSP but they have their own set of other problems to deal with them) for this exact keycaps so they can get away with being as difficult to deal with as they want.
Offline esoomenona
  • Gnillort?
« Reply #918 on: Mon, 04 November 2013, 11:19:53 »
You want I go teach 'em a lesson, lysol? Kneecap 'em or somethin'?
Offline insilica
  • Keyboard Geeza
« Reply #919 on: Mon, 04 November 2013, 11:33:15 »
Jeeeez chill moose. :'(
I guess the way around is to avoid them in future group buys if at all possible.
FreeBSD :: Gentoo :: Arch :: [Project Roswell] :: U2410 Eyefinity :: WC P280 :: 3930K [C2] (4.5GHz)
ASUS Maximus IV :: 64GB Vengeance :: MSI 7970 xFire ::  Seasonic 1KW :: M4 256GB
REALFORCE 87U Silent (Variable) | Filco Majestouch 2 Ninja TKL (Brown) | FC660C
Offline LechnerDE
« Reply #920 on: Mon, 04 November 2013, 11:40:49 »
Yeah, I'd buy more keys than I need as well if it helps reaching MOQ.
But I assume this is for every color, so we'd probably have to buy 300x caps lock for the Irish set, 300x for the Ural set, etc...
Btw, does the blank set also have the wrong caps lock key or is this problem limited to the dyesub ones?
« Reply #921 on: Mon, 04 November 2013, 11:52:58 »
But there really is no good/better alternative :(
« Reply #922 on: Mon, 04 November 2013, 11:58:14 »
All the 2tone key have same. It's because of the keys grouping in the molds. We would have to buy 300x caps lock, homing keys, numpad 0 in beige at least and there might even be some others in there. I suppose alternate homing keys are possibly interesting, not sure what else to really do with beige numpad 0 key besides it being useful for keyboard with 2unit shift.
Right, the only other choice is BSP... and they don't even have fulltouch caps locks, 1.25 keys, or SPACEBARS! Plus they cost a lot more too. Easiest solution if they are going to be problem about 2tone is not to do 2tone and stick to single key color.
« Last Edit: Mon, 04 November 2013, 11:59:50 by IvanIvanovich »
Offline Latin00032
« Reply #923 on: Mon, 04 November 2013, 12:48:14 »
I want to do the stepped caps mod to make it center stemmed. I'm just afraid to mess it up.
Offline esoomenona
  • Gnillort?
« Reply #924 on: Mon, 04 November 2013, 12:54:32 »
I'm sure there are tons of people who don't ever use the stepped caps and it doesn't bother them who would give it up in case someone messed up their mod.
Though, in reality, it should be easy to fix if you mess up. Just Dremel it out again and use another stem and try again. As long as you don't Dremel too much, and have and endless supply of donor stem caps, you're good.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #925 on: Mon, 04 November 2013, 13:02:18 »
I think some people may like the dark home keys.  Hey it frames GH.  :)  The 0 could potentially be useful for some people if we just get it as a blank cap...
Offline cgbuen
    • cgbuen.io
« Reply #926 on: Mon, 04 November 2013, 13:34:09 »
I'm down if we try hitting the 300 MOQ for the fulltouch caps lock mold group in the beige color. I'm sure it would help for buyers of previous two-tone GBs too.
Or another solution would be like Ivan said, start up a GB for inverted two-tone sets, which is an interesting idea in itself. This would be done knowing that they'll have the same fulltouch caps lock error (beige alphas, white mods, but incorrect beige fulltouch caps lock). And then, people who participated in both this and that GB can switch the two proper keys once they receive the sets.
Possibly unlikely due to knowing full well that there's going to be an "error" with the GB beforehand, but just a suggestion.
« Last Edit: Mon, 04 November 2013, 13:36:38 by cgbuen »
Offline esoomenona
  • Gnillort?
« Reply #927 on: Mon, 04 November 2013, 13:37:31 »
Plus, as a plus in the inverted mods, we could do 1x numpad 0 and maybe 00.
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #928 on: Mon, 04 November 2013, 13:38:49 »
Just my opinion, but I don't think this manufacture deserves even more of our money
Offline JPG
« Reply #929 on: Mon, 04 November 2013, 13:39:21 »
If we get a new mold done (I doubt it, but we never know) it would be nice to also get the \ key (above enter) in the same color scheme as the mods to make it symmetric!
Offline esoomenona
  • Gnillort?
« Reply #930 on: Mon, 04 November 2013, 13:41:11 »
@longzilla - I can understand your point of view, but these are really the only place to get these thick Cherry profile PBT caps in custom designs at a nice price. Its not always so easy to walk away.
« Reply #931 on: Mon, 04 November 2013, 14:01:30 »
Exactly, you can pay $120-130 for BSP PBT and not get any 1.25 modifiers and no space bar at all.
« Reply #932 on: Mon, 04 November 2013, 14:50:17 »
Whoneedsspacebarsanyway...whatastupiduselesskeythatis!
Offline rindorbrot
« Reply #933 on: Mon, 04 November 2013, 16:43:19 »
I still want pictures! ;)
Offline phoenix1234
« Reply #934 on: Tue, 05 November 2013, 08:50:50 »
For me, I used this keyboard for small tasks required moving around.
The centre stepped cap locks is acceptable for me.
Here is a better picture
« Last Edit: Tue, 05 November 2013, 08:53:39 by phoenix1234 »
Offline insilica
  • Keyboard Geeza
« Reply #935 on: Tue, 05 November 2013, 09:27:29 »
Hmm this doesn't look half bad TBH. I may do the same :D albeit with black donor caps.
« Reply #936 on: Tue, 05 November 2013, 10:04:09 »
All orders ship as of today.
Re: PBT dyesub 104/105 set ROUND 2 (shipped)
« Reply #937 on: Tue, 05 November 2013, 10:42:42 »
Did my order go out today or earlier?  Is curious!
« Reply #938 on: Tue, 05 November 2013, 13:13:43 »
Excite!  Thank!
Plus another keyboard shipped yesterday too - let's see which arrives first ...
The plan is to unite them when they arrive.
Offline deSheol
  • Thorpe
« Reply #939 on: Tue, 05 November 2013, 13:15:59 »
Let me know if you'd get tired of the PBT set, mate. I am interested in them!  :thumb:
Excite!  Thank!
Offline tobr1an
« Reply #940 on: Tue, 05 November 2013, 14:03:46 »
Me too!@
Offline blighty
« Reply #941 on: Tue, 05 November 2013, 15:03:53 »
It's a shame about the full touch, but it just means I'll have to find a custom board to put my round 1 alphas with my round 2 mods.  Thanks again, lysol/Ivan  :thumb:
42667-0
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
« Reply #942 on: Tue, 05 November 2013, 15:20:50 »
That's quite a looker. Is that MJ2 stock white or did you paint it?
« Reply #943 on: Tue, 05 November 2013, 16:26:24 »
If you're in the USA and haven't gotten your order already it was most likely either shipped Monday or Today. For the most part I sent out orders by forum name alphabetically.
Offline Cafiend
« Reply #944 on: Tue, 05 November 2013, 16:37:32 »
I like the sorting. Thanks man!
Offline blighty
« Reply #945 on: Tue, 05 November 2013, 16:59:21 »
It's a stock off-white Filco Ninja (MX Blacks).  My 'daily' driver.
« Reply #946 on: Tue, 05 November 2013, 16:59:56 »
That should teach me to begin my user names with A or a 0 :D
« Reply #947 on: Tue, 05 November 2013, 17:02:27 »
Sometime I send out by invoice number, or paid on date or...
« Reply #948 on: Tue, 05 November 2013, 17:06:26 »
...and order within the first day of GB's opening!  Min-maxing my group buy experience  :p
Offline berrymxblue
« Reply #949 on: Tue, 05 November 2013, 17:24:22 »
Are there any extras that anyone is trying to unload, please let me know! :thumb:
