Author Topic: [IC] Dual stem location Caps key  (Read 6482 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Wed, 08 May 2013, 21:23:58 »
This is just an Interest Check.  Looking to see who might be interested in a caps lock key with the ability to switch between center and offset stem simply buy pulling the stem out and reinserting into a different position on the cap.  Fair warning I do NOT have the CAD ability, resources, nor contacts to have this done.  What I do have however is a couple ideas on how this could work.  Just wondering if this would be something that people might be interested in.
One idea involves molding added bits into the cap and the other involves cutting the stem and gluing other stuff into the cap.
« Last Edit: Wed, 08 May 2013, 21:39:51 by reaper »
Offline bazemk1979
Re: [IC] Dual stem location Caps key
« Reply #1 on: Wed, 08 May 2013, 22:00:13 »
whats wrong with the current center stemmped stepped capslocks we have from SP? I'm using both beige and black on my cherry sets and they work just fine
Offline Melvang
« Reply #2 on: Wed, 08 May 2013, 22:07:22 »
because then you could get the reg cap and the stepped cap and be able to use both on a board with either center or offset switch.
« Reply #3 on: Wed, 08 May 2013, 22:08:58 »
I think this is a really cool idea. It opens up a few options for capslocks that we could use. Plus I like seeing new fresh ideas ^__^
Offline SmallFry
« Reply #4 on: Thu, 09 May 2013, 00:00:09 »
i3oiler just bought a new mold for stepped center stemmed caps locks. Buying yet another mold is do-able but expensive, plus I'm not sure if it is possible given the space inside the cap.
Offline Melvang
« Reply #5 on: Thu, 09 May 2013, 00:17:45 »
I will see if i can get something drawn up tomorrow.  But like I said in the OP I suck with drawing up stuff on the comp so it will be drawn by hand and then scanned into the comp.  I think I can get my ideas conveyed well enough.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #6 on: Thu, 09 May 2013, 00:24:55 »
I worry that both stems couldn't coexist-- if you're using one, the other would foul against the switch casing.
Overton130, Box Pale Blues.
Offline SmallFry
« Reply #7 on: Thu, 09 May 2013, 00:26:04 »
Good point, sadly.
Offline Melvang
« Reply #8 on: Thu, 09 May 2013, 00:34:36 »
no no no its not 2 stems at the same time.  It is one stem that is removable and has 2 possible positions.
Offline Jocelyn
  • 조셀린
« Reply #9 on: Thu, 09 May 2013, 00:37:49 »
That sounds amazing, but I'd rather have a 1.25x Enter  :p
« Reply #10 on: Thu, 09 May 2013, 04:58:59 »
Melvang, like all good ideas, handsketches are more than fine. I often prefer them at work ^__^
Offline Melvang
« Reply #11 on: Sun, 12 May 2013, 05:24:58 »
OK I have an idea somewhat drawn up but being at work I do not have access to a computer to post the pic.  Will post it when I get home.  On the side of getting say SP to make it them self does anyone have an idea what it would cost to get the molds made?
Edit:  Just to clarify said caps will be sacrificed to the dremel gods.
« Last Edit: Sun, 12 May 2013, 07:10:49 by Melvang »
Offline Melvang
« Reply #12 on: Sun, 12 May 2013, 07:16:09 »
Here is said idea.  Basically it would have 2 portions of a cherry MX stem in the cap.  One for each location, center and offset.  The stem would have the same opening on the top and bottom so as if you want to move it from a center mount to offset just pull the stem and replace in the other location.
Offline thurst0n
  • Key-ping it real
« Reply #13 on: Tue, 14 May 2013, 12:32:01 »
I would be interested.
Thought this would be relevent.
Something like that would require a new mold, possibly 2 and would cost well over $7,000 for SP to do.
http://geekhack.org/index.php?topic=32423.msg890306#msg890306
  :-X
-- Ducky One TKL --
Offline Melvang
« Reply #14 on: Tue, 14 May 2013, 16:05:14 »
Yeah i found that thread after i started this one.
Offline Dubsgalore
« Reply #15 on: Tue, 14 May 2013, 16:32:10 »
Pretty Cool idea
interested ;)
Offline Melvang
« Reply #16 on: Tue, 14 May 2013, 16:41:57 »
How many people have both center and offset caps lock keyboards?
Offline Hak Foo
« Reply #17 on: Sun, 19 May 2013, 00:04:54 »
Well, center stem:
Filco, Rosewill, Cooler Master, Ducky, Cherry 8133/8200
Offset Stem:
Cherry 1800, 11900, 2500, 3000 series
and probably others.
« Reply #18 on: Sun, 19 May 2013, 07:36:40 »
I don't think that would be very stable. It would also be expensive. Better to have two different caps.
