Author Topic: Cherry MX Green  (Read 3688 times)
Offline NDA
Cherry MX Green
« on: Fri, 10 May 2013, 14:07:14 »
Hi,
I am looking for a keyboard that comes equipped with these keys. I have done a little research and I have come across only 3 keyboards 2 Cooler master and one Ducky keyboard that have the cherry MX Green keys, but the Ducky no longer seems available.
Is there any place that would still have the Ducky keyboard with green keys still in stock. I would prefer this over the cooler master keyboards because I am not sure the quality or even the oem of their keyboards they seem to be just alright from my findings.
Offline esoomenona
  • Gnillort?
Re: Cherry MX Green
« Reply #1 on: Fri, 10 May 2013, 14:08:55 »
The CM QFR and Trigger are Costar made, and are of good quality. You shouldn't worry about buying one of them.
Offline NDA
Re: Cherry MX Green
« Reply #2 on: Fri, 10 May 2013, 14:20:13 »
That is good to know. I am still interested in the ducky though is there any place that still carries it. I realize it was a limited edition keyboard but I just figured there might still be some out there.
In any case if not I guess I will have to settle for one of the cooler master boards.
Offline NYCesquire
Re: Cherry MX Green
« Reply #3 on: Fri, 10 May 2013, 15:04:34 »
I'm also on the hunt for a cherry green keyboard.  The ducky to which you refer was a limited run, and none of the distributors expect to see any more.
Are you looking for a TKL or a full 104 keyboard?
Offline mauri
Re: Cherry MX Green
« Reply #4 on: Fri, 10 May 2013, 15:08:22 »
Depends where you're from, and what kind of layout are you looking for. I know a place for the ducky, tho its 105 keys nordic layout
« Last Edit: Fri, 10 May 2013, 15:22:46 by mauri »
I AM BABAR KING OF THE ELEPHANTS
Offline WhiteFireDragon
    • youtube
Re: Cherry MX Green
« Reply #5 on: Fri, 10 May 2013, 15:17:36 »
AFAIK, only those that you already mentioned has mx greens. Ducky's PCB is higher quality, but that shouldn't matter if you're never going to open them up.
Offline Tarzan
  • formerly known as Greystoke
Re: Cherry MX Green
« Reply #6 on: Fri, 10 May 2013, 15:55:20 »
Let me know if you decide to get a full-size keyboard.  I've got the CM Storm Trigger keyboard for sale, it's actually 109 keys (5 extra macro keys).   ;D
Offline NYCesquire
Re: Cherry MX Green
« Reply #7 on: Fri, 10 May 2013, 15:57:42 »
I'm actually interested in that. Can you PM me the details?
Offline NDA
Re: Cherry MX Green
« Reply #8 on: Fri, 10 May 2013, 23:56:23 »
Actually I am not partial to any keyboard size or layout as long as it has the green keys and preferably not a cooler master I am fine. I have had a bad experience with a cooler master keyboard in the past, although I feel the ducky brand would be ideal.
Offline kwago
Re: Cherry MX Green
« Reply #9 on: Sat, 11 May 2013, 08:44:39 »
Ducky is not exactly known for quality for the amount of money you have to pay.
coolermaster keyboards do not all come from the same manufacturer. The Quickfire Rapid w/ mx greens is a very solid board–i've had one for several months now that has been opened and modified and still going strong.
« Last Edit: Sat, 11 May 2013, 08:46:41 by kwago »
Offline TreeSc2
Re: Cherry MX Green
« Reply #10 on: Sat, 11 May 2013, 11:59:05 »
Deff go with ducky if you can. Tty mechanicalkeyboards.com , ducky is well built and well known.
Offline jabar
Re: Cherry MX Green
« Reply #11 on: Sat, 11 May 2013, 12:35:47 »
yeah don't know what you're talking about.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Hak Foo
  • Make America Clicky Again!
Re: Cherry MX Green
« Reply #12 on: Sat, 11 May 2013, 12:54:10 »
The original 1008 series boards were only seen as mediocre quality, but later models have very good reputations.
Overton130, Box Pale Blues.
Offline NDA
Re: Cherry MX Green
« Reply #13 on: Sun, 12 May 2013, 19:41:19 »
It appears the only ducky keyboard that had the green keys was a limited edition run, so unfortunately I am stuck with Cooler master unless there is another brand out there that has these keys.
Offline bore-dome
Re: Cherry MX Green
« Reply #14 on: Wed, 11 September 2013, 20:18:50 »
There is a leopold with MX Greens out there
Re: Cherry MX Green
« Reply #15 on: Wed, 11 September 2013, 20:28:52 »
Offline nuclearsandwich
Re: Cherry MX Green
« Reply #16 on: Thu, 12 September 2013, 02:15:54 »
I've got the Leopold F660M from qtan referenced by rowdy as well as the Ducky 9008G2 available here from MechanicalKeyboards.com
They're both solid boards, though I'm having more trouble adjusting to the Leopold layout than a Poker II, which surprises me and I'd suggest the full size board if this is gonna be a daily driver.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
Re: Cherry MX Green
« Reply #17 on: Thu, 12 September 2013, 02:31:37 »
There is Ducky DK9008 G2Pro with MX-Greens and Grey PBT caps on MechanicalKeyboards. Here is the link. I was just looking at buying one.
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=467
« Last Edit: Thu, 12 September 2013, 02:33:32 by CommonCurt »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline mapple
Re: Cherry MX Green
« Reply #18 on: Thu, 12 September 2013, 05:39:13 »
 they are available as guy above wrote
In God We Trust
