Author Topic: [IC] Poker/GH60 plate/case combo  (Read 50292 times)
Offline domoaligato
Re: [IC] Poker/GH60 plate/case combo
« Reply #50 on: Sun, 12 May 2013, 17:28:21 »
Gh60 universal ANSI here
Offline amzee
« Reply #51 on: Sun, 12 May 2013, 17:43:10 »
Also would be interested in this plate style, without the cutouts for the 1x1 winkey:
Offline RickyJ
« Reply #52 on: Sun, 12 May 2013, 20:46:39 »
Good case idea! I could totally tack some sides onto the plate I ordered to make a cheap case, and remove the sides if/when I get a proper case. :)
This IC isn't for sides that you put on the GH60 plate. This is basically a plate that is bent around to form feet. You wouldn't use the plate you purchased from the GH60 GB.
Oh I know, I was just saying I could do it to save spending more money (takes away from cap sets). :)
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
Offline TheQsanity
  • SmallFry Lovin'
« Reply #53 on: Sun, 12 May 2013, 20:54:58 »
There are no HHKB cases! We should totally do that!
SmallFry! <3
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #54 on: Sun, 12 May 2013, 21:45:02 »
Do these fit inside of current Poker cases, incase I wanted to add another support to my case etc?
I could be wrong, but I seriously doubt it lol
Nope.  Not a chance.
 - Ron I samwisekoi
Offline esoomenona
  • Gnillort?
« Reply #55 on: Mon, 13 May 2013, 09:43:57 »
Oh yeah!!!! These are boss. How much extra to cut the poker suits in the back as well? Also, I just want to make sure, these have the same rake as the stock poker case?
You mean cutouts with the GH60 logo?
Offline SmallFry
« Reply #56 on: Mon, 13 May 2013, 09:49:27 »
Nope.  Not a chance.
 - Ron I samwisekoi
Bah, oh well.
« Reply #57 on: Mon, 13 May 2013, 10:13:52 »
AHH! you know what else I just realized would be ****in awesome for this? A set of front/back rails for support and then interchangeable plates similar to the KMAC plate. not sure if that would end up costing more or less but it would be pretty cool to have the option to swap boards in the same case.
IRC spoke about this at one point... your idea is better I think, but you have no idea how much I wanted something like this avail.
21886-0
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #58 on: Mon, 13 May 2013, 10:34:31 »
Form filled. I'd be interested in two of them, depending on price.
Offline marin
« Reply #59 on: Mon, 13 May 2013, 12:23:29 »
sorry if this is a stupid question but I'm new and I don't understand everything around here yet, will this be "compatible" with the Poker 2 ?
Flynn Lives
Offline mashby
    • Mashby
« Reply #60 on: Mon, 13 May 2013, 15:26:21 »
It should be, but I don't know of anyone that has gotten their hands on one to be sure.
Offline marin
« Reply #61 on: Mon, 13 May 2013, 16:58:36 »
Thank you! I hope it works, I just bought a Poker 2 and can't wait to customize!
Flynn Lives
Offline mashby
    • Mashby
« Reply #62 on: Mon, 13 May 2013, 17:14:24 »
I guess we will know soon because it looks like MK.com will have them the week of May 17th.
Here's a direct link to a Poker 2 with MX-Blues.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #63 on: Mon, 13 May 2013, 19:31:21 »
I don't see why we couldn't do all the plates from the GH60 buy, BUT! know that the less popular ones will cost more. ROGER THAT?!?!
Binge I really like that idea as well. Maybe an acrylic horseshoe shape with stainless plate that slides in...
Anyway back on topic. We have some price quotes but still shopping around. I'm sure Beast will let you know as soon as we get something
nailed down.
Offline iAmAhab
  • Established member
« Reply #64 on: Tue, 14 May 2013, 07:55:38 »
Would definitely be down for one if ISO with 1.25x modifiers(ISO poker?) is available.
Offline Turbo Slaab
« Reply #65 on: Sat, 18 May 2013, 17:18:40 »
No! But I suppose you could include those too :p
Looking for CC's!
Offline Winther
« Reply #66 on: Wed, 29 May 2013, 11:32:38 »
Sorry if this has already been asked.. Any chance of a ISO layout? then I would be in for a couple I think. (depending on price ofcourse..)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #67 on: Wed, 29 May 2013, 18:21:52 »
I don't think jdcarpe would mind drawing up any plate that is wanted. However prices are going to be higher on low quantity plates
Offline esoomenona
  • Gnillort?
« Reply #68 on: Wed, 29 May 2013, 18:45:49 »
I have asked jd for an ISO one. Would you be interested in it? It's ISO 1.5x with a short right shift.
Offline Winther
« Reply #69 on: Wed, 29 May 2013, 20:01:07 »
I would be interested in one or two if its the same as the ISO plate for the GH60. Im not all too familiar with cap/key sizes. But I'm used to a long right shift and 1.25 sizes in the lowest modifier row, however the long shift is not a must I think. But I would prefer the same as the GH60 ISO plate..
Offline esoomenona
  • Gnillort?
« Reply #70 on: Wed, 29 May 2013, 20:05:58 »
Yeah, that is the opposite of the plate I want...
Offline Winther
« Reply #71 on: Wed, 29 May 2013, 20:12:40 »
I could be in for one of both if it isnt too expensive..
Anyways ill fill out the form now that I know ISO is a possibility.. :)
Could this be done for the GH60 by any chance?
« Reply #72 on: Wed, 29 May 2013, 20:18:17 »
Sure, I don't mind drawing plates for any of the plate designs available for the GH60. If someone doesn't mind paying for a low quantity plate, I don't mind drawing it up. :)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #73 on: Wed, 29 May 2013, 20:54:24 »
The dimensions include room for the bends, so the best way to go is to modify one of my DWG files using the Escape key as a locator.
Also, I left the LED hole next to the Caps Lock position, but that can probably be deleted for the GH60.  Do NOT remove the small strengthening braces in the spacebar slot until AFTER the plates are bent.  Otherwise the bending break will distort the spacebar switch hole.
I am also happy to modify or help modify any of the DWG files if desired.
 - Ron I samwisekoi
« Reply #74 on: Wed, 29 May 2013, 22:43:00 »
 - Ron I samwisekoi
Thanks for the tips. That's actually how I copy and paste most of my designs into others. I pick a reference point, such as the ESC key, and draw a couple lines intersecting at the center of that switch hole. Then copy the existing design, using the center of the same switch hole as a reference, and paste into the new plate. Copy with reference is one of the most-used tricks in my drawings.
Also, thanks for the tip about the spacebar slot. I didn't consider that, but it makes sense. The place where I got my lubing station bent has a machine that uses a press, rather than a pan break, to make the bends. If the spacebar slot needs those braces to strengthen it during the bending process, maybe we should just eliminate the slot altogether.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #75 on: Thu, 30 May 2013, 09:55:52 »
I didn't use the slot myself, but some people do, and so I put in those bars so that it would survive the break and then be easy to Dremel open again.  One the flange is bent, the switch hole is not going anywhere!
 - Ron I samwisekoi
Offline esoomenona
  • Gnillort?
« Reply #76 on: Thu, 30 May 2013, 09:58:24 »
Can we see pictures of the drawings? I always like to look at those!
Offline The_Beast
  • I like wood ಠ_๏
« Reply #77 on: Thu, 30 May 2013, 10:00:32 »
Can't say I don't say "yes"
Offline esoomenona
  • Gnillort?
« Reply #78 on: Thu, 30 May 2013, 10:04:16 »
Purty! Though, just out of personal preference, I would say your Poker suits are all wrong. Left to right: Spades, Hearts, Clubs, Diamonds.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #79 on: Thu, 30 May 2013, 10:06:19 »
It is mirrored. So when looking at it it would be, spades, heart, diamond, clubs
So close enough for your moose eyes.... :P
Offline esoomenona
  • Gnillort?
« Reply #80 on: Thu, 30 May 2013, 10:09:11 »
Yes it is mirrored, so wouldn't it be Clubs, Diamonds, Hearts, Spades?
Offline The_Beast
  • I like wood ಠ_๏
« Reply #81 on: Thu, 30 May 2013, 16:12:45 »
I read from right to left.....
Offline esoomenona
  • Gnillort?
« Reply #82 on: Thu, 30 May 2013, 16:16:29 »
Because of all of this, you forfeit any money for that OG. Just mail it to me with the platecase.
Offline oluf
  • formerly olaph
« Reply #83 on: Mon, 03 June 2013, 12:11:55 »
I love this design! I filled in the form for one, but if I could get some TKL variants (eg, phantom) I would buy several more.. What a great platform for PCB-less boards. =)
Offline Dubsgalore
« Reply #84 on: Mon, 03 June 2013, 12:16:07 »
forgot about this...really hope it happens
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #85 on: Mon, 03 June 2013, 14:45:42 »
I know this may be surpassing the point of this a bit, but would it be possible to make it so it has more extension so it can be bent one more time to have tabs on the bottom? I was thinking to have some small tabs on the bottom that could be drilled and tapped, and have a 2nd piece of metal that bolts together to comprise a bottom and sides for a full case. I figure this would still be a relatively cheap option while still offering some protection for the pcb on the bottom and sides just in case, or for possible portability.
24200-0
excuse my crappy illustration.
Offline esoomenona
  • Gnillort?
« Reply #86 on: Mon, 03 June 2013, 14:53:10 »
« Last Edit: Tue, 27 October 2015, 09:24:13 by esoomenona »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #87 on: Mon, 03 June 2013, 14:58:29 »
The guy only has a laser cutter and a break. No drill, no taps so they would have to be taken to a separate shop to be taps (he could more than likely laser a hole accurate enough for tapping) or I could tap them myself. However I've never tapped stainless before.
« Reply #88 on: Mon, 03 June 2013, 15:06:40 »
Oh, well my illustration the top is the side view to explain what I meant by bottom tabs, the bottom would be like front view to show sides coming up. So the bottom would be really simple like just a flat with 2 90 bends for the sides though they would have to be cut with a slope to match the top front to back rise. Then just 4-6 bolts that fasten through the bottom and thread into the top plate piece tabs. I wish I could make a fancy 3D thing to explain what I am talking about but I hope I am making some sort of sense.
Offline esoomenona
  • Gnillort?
« Reply #89 on: Mon, 03 June 2013, 15:08:12 »
Oh, so you want to enclose the entire thing, sides and all, not just the bottom.
« Reply #90 on: Mon, 03 June 2013, 15:13:41 »
Right. It would require about the same amount effort and not too much more in the way of material I guess. If they can't tap, to me that is not a big problem. You could just have people tap the holes themselves, hand taps are not that much.
Offline esoomenona
  • Gnillort?
« Reply #91 on: Mon, 03 June 2013, 15:14:24 »
Personally, I like the sides being open. Gives it a kind of industrial feel.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #92 on: Mon, 03 June 2013, 15:14:59 »
The double bend is a problem for most breaks.  In practice I have found that the straight edge with some U-channel work fine on a flat surface.
Also, it is really hard to solder the top and bottom row without an overhanging flange.  It would be even harder -- and maybe impossible -- to hard-wire a board with Ivan's overhangs.  Moose's idea would be better for that, but the front would have to be raised, as there is only about 3/16" between the desk and the PCB as is.
I did a clear Acrylic bottom plate under my GH75 prototype that rested on the inner lip formed by the U-channel.  That worked pretty well.
I agree the sides should be open.
 - Ron | samwisekoi
p.s.  Hand taps that will cut small threads in SS are expensive.  And prone to snapping.
« Last Edit: Mon, 03 June 2013, 15:16:39 by samwisekoi »
Offline The_Beast
  • I like wood ಠ_๏
« Reply #93 on: Mon, 03 June 2013, 15:18:10 »
Yup, bending the sides depend on the break he has, which I'm not sure of
They could be made of aluminum for easier tapping, but is it strong enough samwisekoi?
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #94 on: Mon, 03 June 2013, 15:21:00 »
I think so, and almost said so above.  For sure it would be strong enough for a Poker-sized PCB.
You would have to be very careful not to strip the threads with steel screws/bolts.
 - Ron | samwisekoi
Offline esoomenona
  • Gnillort?
« Reply #95 on: Mon, 03 June 2013, 15:22:03 »
OOH, and then we could get them anodized!?
« Reply #96 on: Mon, 03 June 2013, 15:23:19 »
I thought I would toss the idea out there. If it isn't feasible no problem.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #97 on: Mon, 03 June 2013, 15:23:57 »
Not to wander TOO far from the inexpensive, bare-bones concept or anything...
[edit]
But Ti would be awesome!
[/edit]
Offline The_Beast
  • I like wood ಠ_๏
« Reply #98 on: Mon, 03 June 2013, 15:24:13 »
Yea, I have a place that I wanted to test out anyways
It's an IC, all ideas are welcome!
Offline esoomenona
  • Gnillort?
« Reply #99 on: Mon, 03 June 2013, 15:25:25 »
[edit]
[/edit]
Are you suggesting 18k gold plating and lasering holes for diamonds?
