Author Topic: Filco MiniLa keycaps verses Das Keyboard Model S keycaps  (Read 2921 times)
Offline alfa147x
« on: Fri, 10 May 2013, 22:21:01 »
Looks like the odd shaped ones down at the bottom are R1 1x1 keys. So now it seems like the only odd key on the board is the Space key.
Here is an album of the key comparison. http://imgur.com/a/WTsLp#0
Any other places sell decently priced custom keys like WASD Keyboards?
Let me know if you would like to see any other comparison pictures.
Offline Hyde
  • White Tofu Extraordinaire
Re: Filco MiniLa keycaps verses Das Keyboard Model S keycaps
« Reply #1 on: Sat, 11 May 2013, 23:18:08 »
They should be similar since both are Costar made keyboards.  Though yes for MiniLa some of the keys will be tricky to replace  :P
