Author Topic: How to fix costar stabilizers?  (Read 1234 times)
Offline pc098
« on: Sat, 11 May 2013, 08:08:53 »
Some of the longer keys on my keyboard are squeaky and stiff; there's a significant difference in typing on the shift key and the backspace key, for example. I don't know why, does anyone have a fix for this?
Re: How to fix costar stabilizers?
« Reply #1 on: Sat, 11 May 2013, 08:09:37 »
Try lubricating the wire. That seems to be the most common response to this issue..
