Author Topic: M13 - removable key caps?  (Read 3892 times)
Offline Waves77
« on: Wed, 18 June 2008, 14:51:46 »
I've tried google without success. Can somebody tell me if the key caps on a M13 are removable?
I'd love to put the black caps on my industrial (grey) model M, so if they do and someone here's selling one let me know (PM)...
Current collection:
\'91 Model M (1391401), \'93 1391401, \'91 Model M (industrial 1394946), Dell AT101W, Apple Extended II (M3501), Cherry G84-4100, Filco FKB 104M/EB, Macally 96, Das III Pro, HHKB Pro 2.
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Wed, 18 June 2008, 14:54:16 »
They are removable, but it's not as easy as on a board with two-piece caps.
Offline meltie
« Reply #2 on: Wed, 18 June 2008, 17:00:40 »
I always thought detachable caps means you can remove the caps with the lettering seperately from the keys themselves. Aren't the keys of a keyboard always detachable? IIRC the M13 has not detachable caps, but of course detachable keys. Or am I misunderstanding something of your anwer bhtooefr (am not native speaker)?
Offline bhtooefr
    • bhtooefr.org
« Reply #3 on: Wed, 18 June 2008, 18:10:53 »
Actually, on some rubber dome keyboards, the keys aren't detachable. And, on scissor boards, it's usually EXTREMELY DIFFICULT to remove the keys without breaking them.
I really should be more careful with my wording, though... I'll try to standardize on this, in the future:
Cap = top part of a key, removable on many Model Ms separately from the rest of the key
Stem = bottom part of a key, engages the keyswitch, separate from the cap on many Model Ms
Key = cap and stem assembly
So, the Model M13 has removable keys, but they're one-piece.
Offline Mikecase00
    • http://www.mikecase.net
« Reply #4 on: Wed, 18 June 2008, 19:30:27 »
Quote from: bhtooefr;5746
That's exactly correct.  My primary board (my avatar) is an extra-clicky 1391401 which I have vinyl-dyed black and swapped in keys (as well as the black metal IBM logo and darker status light cover) from a black M13.
IBM Model M 1391401 (dyed black) w/ keys from M-13
IBM M-13 Trackpoint (naturally black)
IBM Model M 1392934 SpaceSaver
Several plain IBM 1391401 Ms
Epson Equity Q203A
Offline Waves77
« Reply #5 on: Thu, 19 June 2008, 00:20:55 »
Cool, thanks for the info. I really wanted to keep the switches of my favorite model M, and just have the black caps (so no dice using a M13) - all thrown in the body of a grey model M.
Current collection:
Offline meltie
« Reply #6 on: Thu, 19 June 2008, 03:59:41 »
Thanks for clearing this up. I really envy those who own a M13 :-)
