Author Topic: The switches! They do nothing!  (Read 5405 times)
Offline 2097
« on: Fri, 20 June 2008, 02:42:54 »
The dipswitches on my hhkb pro 2, that is. Even out in the linux console, leaving X, showkeys show the same key codes regardles of dipswitch setting. I don't know how I happened to break this thing; unplugging and reinserting it doesn't help. It's a brand new one, too! Argh.
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #1 on: Fri, 20 June 2008, 02:54:50 »
This seems to be going around this forum like a cold. First (though I never talked about it here) I bricked my MK96 attempting a mod and I got pissed off and broke the thing. It  was already having the king F'ed up days when it happened. I liked that thing too. I have another Macally on the way, but it's a different model.
Then Pook F's up his keyboard, and now this.
I hope things only go in threes ...
Offline iMav
  • geekhack creator/founder
« Reply #2 on: Fri, 20 June 2008, 03:22:54 »
Quote from: xsphat
Perhaps we need to look into some anger management sessions for you?  ;)
What sort of mod were you attempting?
Offline lowpoly
« Reply #3 on: Fri, 20 June 2008, 07:28:33 »
Quote from: 2097;5779
Same here on day 1. Then, the next day it worked. I still don't know why.
Maybe XP had to be booted even if it didn't say so, don't remember if I did that.
Offline bhtooefr
    • bhtooefr.org
« Reply #4 on: Fri, 20 June 2008, 09:03:59 »
And the right button on my EnduraPro was feeling really weird, too, although it was covered under warranty - so I've been hit, too.
And that's not counting the M13, although the M13 was in bad shape right out of the box.
Offline Waves77
« Reply #5 on: Fri, 20 June 2008, 09:09:30 »
Ahem
Seems the starts are maligned for buying or modding keyboards these days :)
Current collection:
\'91 Model M (1391401), \'93 1391401, \'91 Model M (industrial 1394946), Dell AT101W, Apple Extended II (M3501), Cherry G84-4100, Filco FKB 104M/EB, Macally 96, Das III Pro, HHKB Pro 2.
Offline 2097
« Reply #6 on: Sat, 21 June 2008, 03:04:43 »
First I tried disconnecting the keyboard. Replugging it back in did not reflect the dipswitch changes.
Then I tried disconnecting the keyboard and all plugged in stuff in the usb hub. Same as above, didn't work.
Then I tried disconnecting everything but waiting a few seconds. That seemed to do the trick. So now it works.
Offline xsphat
  • Enlightened
« Reply #7 on: Sat, 21 June 2008, 03:13:35 »
I wish all our keyboard problems were that easily solved.
Offline 2097
« Reply #8 on: Sat, 21 June 2008, 03:17:41 »
I spoke too soon. It's still messed up. I'll experiment some more and then get back.
Offline bicycle_wreck
« Reply #9 on: Fri, 09 July 2010, 01:12:24 »
Sorry to bump this thread, but this just happened to me.  I rebooted my PC, and all of a sudden my right Alt button became my Windows key and my <> keys became Alt.  However, I have all of the dip switches set to 'on' and I changed nothing--this simply happened out of the blue.
All of the other keys seem to be fine, but none of the dipswitch settings work, and I can't get Alt to actually behave as Alt.  WTF?
Das Keyboard Professional / HHKB Pro 2 / Filco Majestouch Tenkeyless (Cherry Blues)
Offline ch_123
« Reply #10 on: Fri, 09 July 2010, 05:45:10 »
All of them on? I think some of the options are mutually exclusive, so I'd try not having them all on =P
« Reply #11 on: Fri, 09 July 2010, 08:55:07 »
Quote from: ch_123;200943
Trust me, none of them work.  I tried every combination on the back and nothing changed.  Also, to clarify, they worked yesterday.
Offline Rajagra
« Reply #12 on: Fri, 09 July 2010, 08:58:36 »
The only oddity I've noticed with mine is that when I bring my computer out of standby my HHKB won't work until I press a key and wait a couple of seconds for it to wake up and be recognised. Might be because I have Wake Up Enable set on? (I usually use a mouse key to wake the PC up.)
And yes, having all the switches on would cause the Alt/Meta keys to be swapped. Maybe you're looking at them upside down or something and getting confused.
« Reply #13 on: Fri, 09 July 2010, 09:04:47 »
Switch 5 is in the down position (keyboard facing up), which I assumed was off?  Toggling it on or off makes no difference, however.  Sad panda.
Thanks for the reply.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #14 on: Fri, 09 July 2010, 09:05:25 »
You know, if you just got a cheap keyboard you wouldn't have to worry about that.
Offline Rajagra
« Reply #15 on: Fri, 09 July 2010, 09:06:52 »
Quote from: microsoft windows;200968
Do you work for an Indian telephone support company by any chance?
« Reply #16 on: Fri, 09 July 2010, 09:08:08 »
I appreciate your candor, but it's a little late for that.
Offline ch_123
« Reply #17 on: Fri, 09 July 2010, 09:19:28 »
Does it work with other computers?
« Reply #18 on: Fri, 09 July 2010, 09:24:43 »
Nope.  I swapped out the USB cable, too--no change.
« Reply #19 on: Fri, 09 July 2010, 09:30:02 »
Alright, I just plugged it in after having it sit for an hour or so and it works.  Switch 5 is 'off' and Alt is Alt, just as it should be.  WTF?
Happy Panda.
I'll report back if it ****s up again.
