Author Topic: Replacement screws for Poker case  (Read 1893 times)
Offline tadbitnerdy
« on: Tue, 14 May 2013, 11:01:29 »
Hi all!
I recently bought an aluminum poker case, but it didn't come with screws, and the screws for my original case are getting funky (rusting!).  Does anyone know the size/thread of these screws?  I'd like to find hex screws (takes and allen wrench/hex wrench).
-Tad
Offline dndlmx
Re: Replacement screws for Poker case
« Reply #1 on: Tue, 14 May 2013, 17:33:27 »
You could try emailing somebody at KBC / Vortex? I haven't had luck in the past, getting actual replies for this kinda thing. Just in general.
Might have to get out a metric ruler, do some trial-and-error. Here is a chart I've used.
Offline tadbitnerdy
« Reply #2 on: Wed, 15 May 2013, 09:55:03 »
Thanks dnix!
I went to Home Depot and Radio Shack today in the off chance that they have screws this size... and it was a major fail.  However, I might do a retap and use some MDPC screws I have from previous computer builds.
-Tad
Offline jcrouse
« Reply #3 on: Wed, 15 May 2013, 09:57:43 »
Mine is an aluminum case from the iMav GB and may be different but they are #2-56 screws.
Offline Permeability
« Reply #4 on: Wed, 15 May 2013, 12:24:01 »
I think jdcarpe just answered this in the other thread: http://geekhack.org/index.php?topic=40501.msg892792#msg892792
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline tadbitnerdy
« Reply #5 on: Wed, 15 May 2013, 20:09:23 »
Holy crap thanks!  That is exactly what I needed!  Time to browse the intarwebs for this :)
