Author Topic: If you were forced to use a single keyboard for the rest of your life  (Read 12784 times)
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: If you were forced to use a single keyboard for the rest of your life
« Reply #50 on: Wed, 15 May 2013, 09:36:01 »
My GH60
It has reds and Cherry doubleshots.
« Reply #51 on: Wed, 15 May 2013, 09:56:51 »
As for Cherry switches I'm split between MX Red and MX Brown.  Actually I'd probably prefer a switch that's half way between MX Red and MX Black.
I've wanted a switch like that for a while too.  I prefer Blacks to Reds, but Blacks are just a hair too heavy and Reds are way too light.
So what you want is a vintage black switch with 62g springs.  Have that on my KMAC2, it's nice.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #52 on: Wed, 15 May 2013, 10:02:30 »
One of the KMAC's I hand built and programmed or one of my phantoms, though I would have to get it some sort of alu case.
Offline dadgh
« Reply #53 on: Wed, 15 May 2013, 13:29:55 »
KMAC Mini with Clears (Greys on Modifiers), Costar Stabs, O-rings, Thick PBT Keys
Maybe one day when I win the lottery...
« Reply #54 on: Wed, 15 May 2013, 13:38:51 »
Costar on a KMAC?
Offline esoomenona
  • Gnillort?
« Reply #55 on: Wed, 15 May 2013, 13:47:15 »
Custom KMAC plate GB, go.
« Reply #56 on: Wed, 15 May 2013, 13:49:05 »
We'll see... my 2TU should be a thing of legend.
Offline Grim Fandango
« Reply #57 on: Wed, 15 May 2013, 17:20:43 »
Cherry MX browns
Regular OEM PBT keycaps
Costar Stabilizers
Case would be based on aesthetic preference. Some of those Korean boards that people keep posting look amazing, but I do not know what the quality is like.
Offline 1391406
« Reply #58 on: Wed, 15 May 2013, 18:22:59 »
This:
Offline SmallFry
« Reply #59 on: Wed, 15 May 2013, 18:23:23 »
Quite contradictory to your username, don't you think? :))
Offline 1391406
« Reply #60 on: Wed, 15 May 2013, 18:25:44 »
Yep. I've come to prefer the AEK over the Model M.
Offline SmallFry
« Reply #61 on: Wed, 15 May 2013, 18:27:49 »
Heh. I am still not sure what I'd stick myself with.
Offline tipo33
  • "Ski"
« Reply #62 on: Wed, 15 May 2013, 18:37:06 »
I swear by the Model M, but the salmon ALPS in the AEKI still have a special place in my heart.
KM4COL    R.I.P.  SmallFry
Offline 1391406
« Reply #63 on: Wed, 15 May 2013, 19:15:57 »
I love the look and build of the Model M, but the high actuation force has turned me off to using it on a regular basis.
Offline Flyersfan1
  • Hi!
« Reply #64 on: Wed, 15 May 2013, 22:19:52 »
RF 87U 55.
Quote from: Photekq
Offline E TwentyNine
    • Some of My Keyboards
« Reply #65 on: Wed, 15 May 2013, 22:23:17 »
My 1992 Industrial M SSK.
Offline daerid
    • Rossipedia
« Reply #66 on: Wed, 15 May 2013, 23:11:16 »
All this 55g Topre love!!! :D :D :D
Offline davkol
  •  Post Editing Timeout
« Reply #67 on: Thu, 16 May 2013, 11:46:21 »
For the rest of my life? It'd better be rock solid and easy to fix. That means no Topre.
« Last Edit: Thu, 16 May 2013, 12:43:09 by davkol »
Offline Rule16
  • R.I.P. SmallFry
« Reply #68 on: Thu, 16 May 2013, 12:24:13 »
From the keyboards that I have now, it would be the Topre 55gram... but I don't really have that many right now so its hard to tell.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #69 on: Thu, 16 May 2013, 12:37:31 »
Industrial SSK
Offline daerid
    • Rossipedia
« Reply #70 on: Thu, 16 May 2013, 12:45:15 »
That's a very strong point. Based on those factors I might have to go with the ErgoDox
Offline gameaholic
« Reply #71 on: Thu, 16 May 2013, 14:23:36 »
I'm still going with IBM Model M with custom keycaps to add color and replace the useless PrtSc/ScrLock/Pause with Mute/VolDn/VolUp.
However, I may end up wanting a GH75 with Green Switches for most; tactile Gray for spacebar, and Browns for selected mods I hit lightly with my pinkie.  And outboard of that a matching numpad (no arrows), probably Browns with a Green enter key and the plus split into a plus and an equals.  USB pass-through on one device, and Cherry-profile PBT keycaps on all keys.
Do I need to specify the Fn layer of the GH75, or is the above to a "T" enough?
 - Ron | samwisekoi
This Model M.
Which color of these from unicomp would match the model m? Pebble or gray?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
« Reply #72 on: Thu, 16 May 2013, 14:52:45 »
Standard Model M colors are "pearl" and "pebble" in Unicomp lingo.
Those look like pearl, but they would need to be side-by-side to really know.
- D Trump 2026-09-28
Offline knotra
  • I ­­­♥ ⌂ ♫
« Reply #73 on: Thu, 16 May 2013, 19:42:35 »
Beige Filco Ninja Majestouch-2 with clear switches (if this was like a dream)
in reality:
Beige Filco Ninja Majestouch-2 with browns or blues
Keyboards: Razer Blackwidow Ultimate, Das Model S Ultimate Tactile Soft, Das Model S Professional Tactile Click, Corsair Vengeance K90, Steelseries 6gv2 Black Switch, Filco Ninja Majestouch-2 Soft Linear Action, Ducky DK9087 Shine II w/ Browns, Ducky DK9008 Shine II w/ Blues, WASD Keyboard v1 w/ Browns, Leopold FC200R Tacticle Touch, White Filco Majestouch-2 TKL Click Action, Ducky DK9008G2 PRO Dark Grey Version PBT w/ Clears, Realforce 87U Tenkeyless 45g White/Grey
Offline domoaligato
« Reply #74 on: Thu, 16 May 2013, 19:47:47 »
Gh60 with red switches and gold 62g springs. Fully backlit with all red imsto pbt caps. Duck poker case.
Offline BearHug
« Reply #75 on: Fri, 17 May 2013, 03:40:43 »
My HHKB definately
HHKB2  Noppo Choc mini (Browns) CM Storm TK (Reds) Blackwidow (Blues) Ozone Strike (Blacks)
