Author Topic: Touchscreen Gaming Buttons  (Read 4031 times)
Offline Rule16
  • R.I.P. SmallFry
« on: Wed, 15 May 2013, 21:35:30 »
Anyone know of anything like these steelseries ones? http://www.amazon.com/dp/B00AROMN8G/ref=cm_sw_r_an_am_ap_am_us?ie=UTF8
I don't want to get those because I need 4 and I'd have to buy two, so is there anything like this but with four buttons?
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline captinchikin
Re: Touchscreen Gaming Buttons
« Reply #1 on: Sun, 09 June 2013, 16:35:02 »
After looking at this, it actually looks like you might be able to build your own. Some sort of reusable adhesive+the rubber dome caps from inside some old keyboard. If you don't have an old keyboard, you can get something for like $5, and that's way less than this $20. As for the joystick...Maybe that one would be a bit more complicated.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Sun, 09 June 2013, 16:46:45 »
Hmmm, aren't RDs these days conductive?  You need capacitive to work with a touch screen.
Filco w/ Imsto thick PBT
Offline Rule16
  • R.I.P. SmallFry
« Reply #3 on: Sun, 09 June 2013, 22:32:59 »
I think so, but an interesting idea either way... I'm sure I have an old rubber dome around somewhere.
Dvorak Only Zone
