Author Topic: Keycaps and Nail Polish  (Read 23703 times)
Offline berserkfan
« on: Thu, 16 May 2013, 12:03:17 »
Hey folks
Please share your experience with using nail polish on keycaps.
Firstly, how does nail polish feel on a keycap? Does it improve the feel?
Secondly, how lasting is nail polish on keycaps?
Does it protect ABS keycaps from shine? I am thinking of using transparent nail polish on doubleshots, but I don't want to sacrifice any doubleshots as victims.
Let's say we have a pad printed keycap. We want to protect the legends so they don't wear off. Will putting a layer of transparent nail polish help?
Alternatively, if we have laser-etched keycaps, would putting colored nail polish help change their colour?
Please share your experiences!
Offline BunnyLake
  • The OG HHKB Master
  • X
Re: Keycaps and Nail Polish
« Reply #1 on: Thu, 16 May 2013, 12:07:26 »
dont do it would be the short answer to this
it takes a lot of trial and error to get things right, and there is a lot more to the process than just painting them if you want them to feel and look right
« Reply #2 on: Thu, 16 May 2013, 12:28:00 »
My daughter and I made a few nail polish caps which have held up "pretty well" but when you consider that most of the keys that I am typing on were made when Ronald Reagan was president and still look and feel great, well, no surface-applied film is going to hold up like that!
If you get a year or 2 of good use you should consider yourself lucky, and that is assuming that they are used as accents on lesser-used keys.
- D Trump 2026-10-24
Offline berserkfan
« Reply #3 on: Fri, 17 May 2013, 07:48:56 »
Fohat, can I ask you how they feel? I am totally ok with the idea of painting and repainting every year. Like most people on this site I am quite happy to put in a bit of effort to improve my stuff. I just want to know if nail polish can do any or all of the following:
1)   protect pad printed keycaps from losing their legends via normal usage
2)   create a transparent layer to prevent ABS doubleshots from suffering Shine
3)   change the texture of some PBT keycaps
4)   change the colour of an ABS keycap without having to boil it in dye
Since I am male, I have seriously zero understanding of nail polish. And my mother comes from the generation that never used nail polish; any female friends I know have no concept of using nail polish to do hobbying so there’s no info coming from them either.
Offline Photoelectric
« Reply #4 on: Sat, 18 May 2013, 14:25:48 »
As someone who used to use nailpolish a lot (on my nails), I'd advise against using it on keycaps.  Nailpolish is not made to be durable like oil-based paints for cars and such.  It will wear off fairly quickly with use, as it wears off nails.  I would advise against using normal oil-based spray paint as well, because, while durable, it will feel sticky.  Instead I would look into getting white / light keys and dying them with something like RIT (mixed results there too, from what I've read).  Your safest bet is to spray paint with oil enamel if you don't mind the sticky feel or perhaps try Plasti-dip.  Or just buy keycaps already made in colors you like.
« Reply #5 on: Sat, 18 May 2013, 14:41:07 »
I have only done it on decades-old IBM PBT, and the texture does not change all that much. We did it only for specialty decorative purposes.
The above response surprises me (what do I know? I'm an old man) because I always thought that nail polish had to be particularly tough and resistant, and considered it to be like "super-paint" when I use it at the work bench.
Personally, I consider the answer to all 4 of these questions to be "no" on at least some level. Adding a "skin" layer is good for some things (like UV protection) but seldom appropriate for abrasion resistance since it wears unevenly. Short-term, you might get something you really like, but don't expect it to last.
Offline Badwrench
  • ummmm.....I forgot
« Reply #6 on: Sat, 18 May 2013, 16:51:52 »
I am going to have to agree.  Using nail polish on some keys for fun is one thing, but for regular use, I don't think you will be happy.  One thing to note is that most nail polish is very high gloss, so picture the most used, glossy keys you have ever seen, and that will roughly be the finish.  I am not sure if there is a satin finish, but I would stay away from trying to protect your keys and just wash your hands more.  The oil does the most damage.
Offline berserkfan
« Reply #7 on: Sat, 18 May 2013, 21:49:18 »
Excellent, Excellent!
If answer from fohat is no on all counts, that’s really what I wanted to hear.
But doesn’t that raise the question of the keycaps that some people’s girlfriends here have created with nail polish? These look absolutely stunning, but if these works of art are not meant to be typed on, it would never be worth my $20 to buy.
Offline quake4mhg
« Reply #8 on: Sun, 19 May 2013, 01:24:34 »
Any pictures? I'm interested how they look like  :rolleyes:
« Reply #9 on: Sun, 19 May 2013, 08:31:24 »
They look very cool, and are really easy. It is basically a matter of floating a few drops of nail polish on water and dipping the key into it.
Offline BunnyLake
  • X
« Reply #10 on: Tue, 21 May 2013, 08:50:34 »
Offline AGmurdercore
« Reply #11 on: Wed, 22 May 2013, 09:04:03 »
BUNNY WTF WHY ARE YOU DOING THIS TO US????
Edit: I'd say that this is amazing but no, this is something more :O
What the hell am I even doing
Offline BunnyLake
  • X
« Reply #12 on: Wed, 22 May 2013, 09:07:04 »
that was a cutom order for sir jdcarpe himself and itll be shipping on friday
« Reply #13 on: Wed, 22 May 2013, 09:26:48 »
I know what it is but i want to know why are you showing it to us, you make us jelly! :D
Joke aside, this is a really well done job mister and congratz to jdcarpe for getting this awesome set ^^
« Reply #14 on: Wed, 22 May 2013, 09:34:04 »
Forget nail polish. Eraser rubber is the way forward.
« Reply #15 on: Thu, 23 May 2013, 01:35:03 »
I can only imagine how scratchy it is ;). Unless it was coated with clear.  Looks cool!
Offline Tym
« Reply #16 on: Thu, 23 May 2013, 02:17:29 »
Bunny said they were smooth, I cant remember the exact words; but very very smooth.
Offline quake4mhg
« Reply #17 on: Thu, 23 May 2013, 05:02:16 »
Omg! They're beautiful!! Thanks for the pictures Bunny  :D
Offline Grim Fandango
« Reply #18 on: Thu, 23 May 2013, 05:23:56 »
Proceeds to post pictures that makes every guy in here rush to their wives/girlfiends/sisters nail polish stash to try it out themselves.  :))
(Only to bitterly disappointed)
« Reply #19 on: Thu, 23 May 2013, 08:35:36 »
That's right, my wife would have ridiculed me.
That's why I went to my 15-year-old daughter, who thought it was a cool idea.
« Reply #20 on: Thu, 23 May 2013, 08:39:12 »
you mean pliatex?
Offline TotalChaos
  • Indy Game Coder
« Reply #21 on: Thu, 23 May 2013, 17:04:08 »
Dear BunnyLake,
Are your AmazinglyStupendouslyWonderfull keycaps made with nail polish or real paint?
Offline BunnyLake
  • X
« Reply #22 on: Thu, 23 May 2013, 17:22:38 »
Dear BunnyLake,
a little from colomn a and occasionally from column b depending on what im doing
if you ever want any shoot me a pm
Offline TotalChaos
  • Indy Game Coder
« Reply #23 on: Thu, 23 May 2013, 18:56:45 »
You remind me of Archer(tm)  ;D
« Reply #24 on: Sun, 02 June 2013, 10:29:15 »
I was messing around with nail polish today and here is the result:
http://imgur.com/a/e9IZb
As you can see only one (the black on green) cap is cherry MC cap and the rest are just some old caps from old rubber dome board.
Offline Badwrench
« Reply #25 on: Sun, 02 June 2013, 11:37:16 »
Did you paint over a white or beige cap?  I did mine over doubleshots and they don't light up like yours.
« Reply #26 on: Sun, 02 June 2013, 12:36:54 »
The green on the is shining is a green blank key cap from the WASD sampler pack and the other 2 are just random caps from old rubber dome keyboard as said above. I am trying to find some more caps as i don't have any i can use for this right now and will update with more results if i am able to craft some more.
« Reply #27 on: Mon, 24 June 2013, 12:45:23 »
I have painted some more recently trying different combinations on some old caps from a rubber dome and will post pics as soon as i can :)
Offline ImperfectLink
« Reply #28 on: Mon, 01 July 2013, 08:11:45 »
Lol I like the poses in the pics bunny.
