Author Topic: Media Player  (Read 14197 times)
Offline godly_music
Re: Media Player
« Reply #50 on: Fri, 28 February 2014, 19:48:16 »
foobar2000 is the obvious pick for Windows unless you're heavily Appleized.
MPC-HC, LAV Filters and madVR also work beautifully together, although the new madVR scaling is too GPU intensive. I preferred the Intel-optimized ffdshow builds for upscaling via CPU, but sadly ffdshow is no longer being actively developed.
Offline TheSoulhunter
  • ~ BOOO ~
Re: Media Player
« Reply #51 on: Sat, 01 March 2014, 04:52:44 »
...but sadly ffdshow is no longer being actively developed.
Work with Milan (the original dev) was nice as he was open for suggestions and critic, you supplied some code or a lib, explained it's benefits and it was implemented, I wish he would come back ;_;
The tryouts team focused mainly on bugfixing and optimizing, which is fine, but they didn't took any input (at least from me), that's why there were not much new features for ages...
A Ghost From The Past
Offline Vibex
  • Love y'all
Re: Media Player
« Reply #52 on: Tue, 11 March 2014, 17:35:05 »
On *nix I use cmus for music and smplayer for video.
On windows I use foobar for music and Media Player Classic for video.
Offline StylinGreymon
  • Keyboard Hipstar
Re: Media Player
« Reply #53 on: Tue, 11 March 2014, 17:42:32 »
Back when I used Windows, I used Foobar2k, which is a fantastic music player, MPC-HC for video.
On Linux, I use mpd+ncmpcpp, which, aside from its shoddy .cue support is quite nice, and SMplayer for video.
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline Smasher816
  • HHKB Master
Re: Media Player
« Reply #54 on: Tue, 11 March 2014, 18:50:45 »
I'm running a pretty minimalist Linux install so I use mpd with ncmpcpp.
Long live the terminal :)
Offline blackbox
Re: Media Player
« Reply #55 on: Sun, 16 March 2014, 15:01:26 »
Foobar2k on windows. Moc in Linux and mplayer in both.
The LAN table!
Offline FrostyToast
  • Litshoard
Re: Media Player
« Reply #56 on: Thu, 03 April 2014, 21:40:45 »
Guys, I finally switched to Winamp after finding out that iTunes doesn't support MIDI files. Hooray! And the reason why I did this is because I recently found out about Black MIDI music which is the craziest stuff in the world! You should check it out if you haven't.
Quote from: elton5354
Offline Smasher816
  • HHKB Master
Re: Media Player
« Reply #57 on: Thu, 03 April 2014, 21:46:35 »
It's sad that Winamp finally died :(
Offline FrostyToast
  • Litshoard
Re: Media Player
« Reply #58 on: Thu, 03 April 2014, 22:26:09 »
It is sad, but it still works!
Offline roaming pear
  • THE Roaming Pear
Re: Media Player
« Reply #59 on: Wed, 23 April 2014, 20:13:51 »
I like music bee.  Not sure why, but I like it.  I guess it just some how works for me..
Does anyone have any accessories or key caps or other poker 2 related things lying around that they are not using?  I don't mind taking it off your hands if you no longer want it...
Offline Coreda
Re: Media Player
« Reply #60 on: Fri, 25 April 2014, 02:13:36 »
Seems like they're working on something according to the new site. As I no longer use Winamp my only concern was the amazing collection of skins would be lost. Apparently not, thankfully.
