Author Topic: Question about the Noppoo Choc mini  (Read 1900 times)
Offline Ferdowsi
« on: Fri, 17 May 2013, 14:44:44 »
For the keyboard, are the actual keycaps smaller than your "standard" keycap?
Offline polpo
    • http://polpo.org/
Re: Question about the Noppoo Choc mini
« Reply #1 on: Fri, 17 May 2013, 15:36:16 »
They're slightly lower-profile (less tall) than typical Cherry switches, but otherwise are completely standard.
I'm wrong.
« Last Edit: Fri, 17 May 2013, 16:31:03 by polpo »
Matias Mini Quiet Pro / DSI SMK-88 (Cherry Black) / IBM Model M (10 Jul 86) / ThinkPad Travel Keyboard with Ultranav
Offline davkol
  •  Post Editing Timeout
« Reply #2 on: Fri, 17 May 2013, 16:09:56 »
Huh?
They're Cherry-profile (same height as Cherry keycaps).
Offline Ferdowsi
« Reply #3 on: Fri, 17 May 2013, 16:10:45 »
Any downsides to this keyboard i should know about?  I am thinking of picking it up.
« Reply #4 on: Fri, 17 May 2013, 16:12:44 »
Isn't the spacebar a little off? I forget. If you post in the Simple Questions Simple Answers thread, I'm sure an expert will know.
Offline Lunartuna
  • Good bye money!
« Reply #5 on: Fri, 17 May 2013, 16:14:33 »
Some people have posted having a couple odd problems. Mine works great so far. My only gripe is the odd size space bar which you will never find a replacement for and they never have choc mini size in group buys that I've seen.
Shine 2 TKL - Choc Mini
Offline polpo
    • http://polpo.org/
« Reply #6 on: Fri, 17 May 2013, 16:33:12 »
Huh?
Whoops, sorry for the wrong info. They just looked shorter than all the other boards with Cherry MX keycaps that I've used, but either those other boards didn't have Cherry profile or I just judged the height incorrectly.
Offline davkol
« Reply #7 on: Fri, 17 May 2013, 16:33:52 »
Some people have issues with keys registering more times than expected, this may be fixable though.
Choc mini doesn't work on OS X out of the box.
Stabilizers need to be lubed. Spacebar is different from anything else, but it doesn't really matter since default keycaps are pretty awesome.
Offline BlueMica
  • 1994 RX-7 R2 GT35R 500+AWHP 2004 Subaru STI GT45R
« Reply #8 on: Sat, 18 May 2013, 20:00:23 »
There's a real big problem with "rebounding" with these keyboards and I don't know if its the Cherry MX Red switch or the keyboard itself that causes it, but Fn + F10 fixes this problem.
Noppoo Choc Mini Black POM Cherry MX Red | Filco MJ1 Cherry MX Blue | Realforce 87U "EK-Edition" |1989 IBM SSK | Filco Ninja Cherry MX Brown | Filco Zero TKL
