Author Topic: FC660M with Whites (or perhaps they are Clears)  (Read 2189 times)
Offline therecorder
« Last Edit: Mon, 20 May 2013, 08:52:41 by therecorder »
Offline Jocelyn
  • 조셀린
Re: FC660M with Whites
« Reply #1 on: Mon, 20 May 2013, 08:41:03 »
Nice, but it probably has clears. Milk is white in Asia, while white generally means clears. I might get an FC660M w/ clears to mod, if I wind up not liking the FC660C, though I'm fairly confident that I'll like it :)
« Last Edit: Mon, 20 May 2013, 08:43:06 by Jocelyn »
Offline therecorder
« Reply #2 on: Mon, 20 May 2013, 08:45:06 »
You're probably correct, and, if it is Clears, I may be interested.  Says that there are 20 in stock, but on Taobao only an agent, like Qtang, can find out for sure.
« Reply #3 on: Mon, 20 May 2013, 08:46:05 »
Also just for an fyi most of the time when it says 'green' they are really 'blue'
Offline aggiejy
Re: FC660M with Whites (or perhaps they are Clears)
« Reply #4 on: Mon, 20 May 2013, 11:12:40 »
I'd buy it if it were whites... but I highly doubt it.
Offline tinlong117
« Reply #5 on: Tue, 21 May 2013, 05:54:36 »
youre right.
Offline therecorder
« Reply #6 on: Wed, 22 May 2013, 05:50:56 »
AS USUAL, QTANG COMES THROUGH...  "CLEARS" ARE AVAILABLE IN THE "SELECT: SWITCHES" DROP-DOWN:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-sw/leopold-fc660m-mechanical-keyb/lid=35177400
