Author Topic: Filco Majestouch dying. Loosing key functionality.  (Read 1181 times)
Offline killeraxemannic
« on: Mon, 20 May 2013, 18:02:24 »
Ok so I have a Majestouch and I am pretty sure it is dying.
It started out by loosing the up arrow, left arrow, end, home, and page down keys. They just stopped working one day. Then about 3 months later it lost the right enter key and the plus key.
I took it apart and did not find anything out of the ordinary. No corrosion or cracks on the circuit board etc.
I was thinking the controller chip that is in the top right corner needs replacement but I have not been able to find one.
Any ideas what to do?
Offline aggiejy
Re: Filco Majestouch dying. Loosing key functionality.
« Reply #1 on: Mon, 20 May 2013, 18:42:28 »
Normally I'd have said you could have a switch or two fail, but that's very rare and seems very improbable to have as many as you say go out.  I suppose it could be the controller (which is wrapped around the top of the arrow keys)... but never heard of that happening.
Is it a Majestouch 2?
« Reply #2 on: Mon, 20 May 2013, 19:12:49 »
I think its the Majestouch 1. It says FKBN104M/EB on the sticker on the back.
