Author Topic: ID this switch?  (Read 2522 times)
Offline 1391406
ID this switch?
« on: Tue, 21 May 2013, 02:24:21 »
From a 1989 Pravetz keyboard. Anyone know what it is?
Re: ID this switch?
« Reply #1 on: Tue, 21 May 2013, 02:53:18 »
I'm assuming you're looking at this keyboard on eBay, correct?  It's this keyboard (another link).  The PCB shots on the eBay page are more helpful to me.  If it is mechanical, it's got to be some permutation of a buckling spring or spring over rubber dome keyboard (Ripster lays out a few here) given the back side of the PCB.
I'd love someone to chime in and say I'm wrong that it's Hall-Effect or some other uncommon switch.
« Last Edit: Tue, 21 May 2013, 12:55:48 by nubbinator »
Offline 1391406
Re: ID this switch?
« Reply #2 on: Tue, 21 May 2013, 03:04:06 »
That's the one.
Offline BlueBär
Re: ID this switch?
« Reply #3 on: Tue, 21 May 2013, 07:25:53 »
The PCB shots on the eBay page are more helpful to me.  If it is mechanical, it's got to be some permutation of a buckling spring or spring over rubber dome keyboard.
As you can see from the pictures there defintely is a rubber dome, I guess the spring is under that white slider. Never seen that switch though.
Offline terran5992
  • One With The Cup Rubber
Re: ID this switch?
« Reply #4 on: Tue, 21 May 2013, 09:34:34 »
Looking at the stem ,I'm guessing its made by cherry.
Re: ID this switch?
« Reply #5 on: Tue, 21 May 2013, 09:59:49 »
I have bought several plunger-over-dome keyboards that were MX compatible but not Cherry (including Packard Bell and Gateway).
Look at how rounded the tips of the cruciform are - usually they are hard and square.
- Franklin Roosevelt 1933
Offline BlueBär
Re: ID this switch?
« Reply #6 on: Wed, 22 May 2013, 04:30:00 »
No, in fact, most mechanical switches have these cross-style stems. There is no indication that this switch was made by cherry. Also I don't think cherry every made a spring and dome switch.
Re: ID this switch?
« Reply #7 on: Wed, 22 May 2013, 09:52:44 »
From what I can see through the semi-transparent PCB, it looks like it uses some kind of conductive pad on the bottom of each slider. Whether is has conductive rubber or foam and foil, I can't tell.
