Author Topic: Question about key caps?  (Read 3144 times)
Offline SeriouSSpotS
  • 60% is love, 60% is life
« on: Tue, 21 May 2013, 06:14:16 »
Does anyone know if key caps from a keyboard with my switches fit on mx switches if they are the older type?
Offline BlueBär
Re: Question about key caps?
« Reply #1 on: Tue, 21 May 2013, 07:48:36 »
I don't know what you mean with "the older type", but generally 1x1 Cherry MY caps fit onto Cherry MX stems. More info on that here.
« Reply #2 on: Tue, 21 May 2013, 08:14:31 »
I did have a read though that page, i guess I meant to say the older generation of switches.
Offline Tym
« Reply #3 on: Tue, 21 May 2013, 08:15:07 »
Not sure what you mean, if you can provide pictures, that would be of great benefit.
« Reply #4 on: Tue, 21 May 2013, 09:06:47 »
I am having trouble finding pictures, if you look the link that BlueBär posted there is a couple on there. From what I can see they seem to be similar, I think it is just a case of me finding the right layout.
« Reply #5 on: Tue, 21 May 2013, 09:08:33 »
Which switches? The older MY or older MX?
« Reply #6 on: Tue, 21 May 2013, 09:20:02 »
Would the key caps used on the older generation of MY switches fit current MX swicthes
« Reply #7 on: Tue, 21 May 2013, 09:23:07 »
Yes, there was just a Group Buy through inlikeflynn that harvested caps from Cherry MY7000 boards for MX users. Also mashby has pictures of his Poker with caps from a MY7000 board.
« Reply #8 on: Tue, 21 May 2013, 09:25:48 »
That is interesting, Thanks for the reply  :).
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Tue, 21 May 2013, 10:56:51 »
MY and MX use all the same keycaps with the exception of bottom row 1.25 keys and stabilized keys on current PBT sets which the MY version is not compatible.
« Last Edit: Tue, 21 May 2013, 11:00:25 by IvanIvanovich »
« Reply #10 on: Tue, 21 May 2013, 11:28:42 »
Great that's what i needed to know, Thanks much appreciated
Thanks to everyone for their replies.
