Author Topic: Any ALPS with Euro Layout?  (Read 5936 times)
Offline Bluemercury
« on: Fri, 27 June 2008, 20:59:19 »
I've decided to buy HHKP2 after the praise it gets here, and because i dont like laptops keyboarsd, i've decided to buy a small one or space saver, :P, for my new Clevo. Still i think might want to get an alps keyboard, but they seem hard to find, specially with an euro Layout.
Any ideas?
Collection:
Das Keyboard II
Model M5-2
Model M5-1(considering selling this one)
Cherry G80-3000LCMPO with black switches
Cherry G80-5000HAMPO (Brown switches)
McAlly96
HHKP2 BNx2
Offline iMav
  • geekhack creator/founder
« Reply #1 on: Sat, 28 June 2008, 05:14:05 »
Pick yourself up a HHKB Pro 2 and enjoy!
Offline IBI
« Reply #2 on: Mon, 30 June 2008, 09:15:50 »
Dell AT102/AT102W is a 102/105 key keyboard (Not sure if it's labled as anything other than UK layout) with black alps. Can be found in beige and occasionally black.
There's also the two Apple Extended keyboards, but you'd be looking at a extra cost for the ADB to USB converter on top of that price.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline lowpoly
« Reply #3 on: Mon, 30 June 2008, 09:30:52 »
And the Apple Adjustable.
The Dell is also available from SGI, in that case make sure it's PC compatible.
Offline IBI
« Reply #4 on: Tue, 01 July 2008, 10:17:15 »
Quote from: sofa king;6075
Is the SGI availible in Euro shape or only US shape?
Offline lowpoly
« Reply #5 on: Tue, 01 July 2008, 11:11:39 »
If not you should be able to transplant Dell technology into the SGI. Keycap color looks the same on clickykeyboards.com.
Offline lowpoly
« Reply #6 on: Wed, 02 July 2008, 04:14:12 »
I asked the SGI forum. The AT-102 is available from SGI with german layout at least. That seems to be the difference between 101 and 102. 101 has the horizontal enter key, 102 the vertical. That also explains why my Dell AT-102W has QWERTY layout and the vertical enter key.
Offline IBI
« Reply #7 on: Wed, 02 July 2008, 09:23:59 »
Quote from: sofa king;6182
Thanks for confirming there's an AT102.
AT-102 are the 102 key versions (7-shaped enter, backslash by the right shift), AT-101 are the 101 key versions (bar enter, oversized left shift). The W on the end is the three extra windows keys (presumably not availible on the SGI models?)
Offline lexicon
    • http://www.word-detective.com
« Reply #8 on: Tue, 09 September 2008, 19:57:52 »
By the way, as a recent purchaser of both the Dell AT 101W and a vintage SGI AT-101, I was surprised at the difference in the quality of construction of these boards.  While the Dell is nice, and certainly far more solid than current Dell boards, the SGI is far heavier and far more sturdily built.  The key action is not as clicky as the Dell but far smoother and more solid.
It's pretty clear that Dell licensed the design from SGI (the boards are visually identical except for the color) and proceeded to cut corners right and left.
The "granite" case of the SGI is a bit strange (it's supposed to look like actual granite, with little specks in the plastic), but, on the other hand, it certainly won't show fingerprints and cookie crumbs.  Pretty crafty.
IBM Model M 1391401 (1989)
IBM Model M 52G9658 (1993) x2
Unicomp Customizer 101 (black)
Solidtek ASK-6600U
Dell AT101W (way too many)
Dell AT101W (black)
Silicon Graphics AT-101 (1993)
Cherry G84-4100
Offline lowpoly
« Reply #9 on: Wed, 10 September 2008, 02:29:25 »
I have a Dell AT-102 that has a 4mm metal plate bolted to the lower case. No electrical connection, no anything, just an added weight. My other Dells don't have that. So that might explain why some ATs are heavier than others.
Also, the pcb of that Dell has Silitek printed on it. It's also a Silitek controller. Silitek - now a part of Lite-On - is a keyboard company that has been around for quite some time so it's highly likely that both Dell and SGI got a Silitek OEM model here.
Offline Bluemercury
« Reply #10 on: Wed, 10 September 2008, 08:05:26 »
Quote from: lexicon;8628
Where to get those?
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline Waves77
« Reply #11 on: Wed, 10 September 2008, 14:59:11 »
Quote from: Bluemercury;8642
Where to get those?
Check ebay. I have a Dell AT101W as well, very nice board.
Current collection:
\'91 Model M (1391401), \'93 1391401, \'91 Model M (industrial 1394946), Dell AT101W, Apple Extended II (M3501), Cherry G84-4100, Filco FKB 104M/EB, Macally 96, Das III Pro, HHKB Pro 2.
Offline lexicon
« Reply #12 on: Wed, 10 September 2008, 16:00:12 »
The SGI is definitely a different board from the Dell.  The plastic is much heavier, the key action is much smoother, the general feel of quality -  fit and finish -- much higher.  Visually, they are identical, but that's as far as it goes.
I got my SGI on eBay, $46 bucks.
Solidtek ASK-6600U
Dell AT101W (black)
Cherry G84-4100
Offline Bluemercury
Collection:
Das Keyboard II
Model M5-2
McAlly96
HHKP2 BNx2
Offline bigpook
« Reply #14 on: Wed, 10 September 2008, 18:05:49 »
Offline lexicon
« Reply #15 on: Wed, 10 September 2008, 18:07:47 »
This is the one I bought:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=290257667032
This seller had another up after mine with a lower serial number (grrr....), but apparently it's been sold.  He sells some interesting stuff -- see his other auctions.
By the way, the description on the item you link to is copied from the clickykeyboard site, which also sold the SGI boards (they are out of stock).  I bought my Dell AT-101W from them and they had done a super job of cleaning it up.
Anyway, you might drop a line to that ncbound 10 at eBay and ask if he has any more SGIs in his pipeline.
Solidtek ASK-6600U
Dell AT101W (black)
Cherry G84-4100
Offline Waves77
« Reply #16 on: Wed, 10 September 2008, 19:02:31 »
I've bought from that guy (ncbound10) as well, good seller.
Current collection:
Offline lexicon
Solidtek ASK-6600U
Dell AT101W (black)
Cherry G84-4100
Offline ch_123
« Reply #18 on: Thu, 23 October 2008, 16:34:48 »
I thought my Keyboard buying days were over when I got my Unicomp, but yesterday I used a computer equipped with a Dell AT102W and fell in love with it on the spot. I've ordered one from Ebay, oddly enough, despite being a UK layout, it came from a US seller. He doesnt seem to have any more unfortunately. However, maybe he's just selling them one at a time, here's a link to the seller's shop below -
http://stores.ebay.ie/SALESPCPLUS_W0QQfcdZ2QQfciZQ2d1QQfclZ3QQfromZR10QQfsnZSALESPCPLUSQQfsooZ1QQfsopZ1QQsaselZ185220999QQsofpZ0QQtZkm
