Author Topic: Keycap & Keyboard Photography  (Read 3711764 times)
Offline HPE1000
  • Keycap Paparazzo
Re: Keycap & Keyboard Photography
« Reply #850 on: Fri, 31 October 2014, 15:48:23 »
Happy Halloween!
« Last Edit: Fri, 31 October 2014, 15:50:45 by HPE1000 »
Offline Zeal
    • Zeal Generation Inc.
« Reply #851 on: Fri, 31 October 2014, 15:50:09 »
Happy Halloween!
So that bowl will be outside your door, right? ;)
« Reply #852 on: Fri, 31 October 2014, 15:50:37 »
Happy Halloween!
PLS NO
« Reply #853 on: Fri, 31 October 2014, 15:51:32 »
I'll only take one piece.  :D
Offline HPE1000
  • Keycap Paparazzo
« Reply #854 on: Fri, 31 October 2014, 15:53:46 »
Happy Halloween!
I hope not XD
(Not like anyone would even take one)  :P
Offline tyvar1
  • Otto is a Rhino!
    • Reddit
« Reply #855 on: Fri, 31 October 2014, 18:12:10 »
Happy Halloween!
Trick or treat! (In this case I really hope I get a treat ;) )
Offline frosty
  • jukebox hero
« Reply #856 on: Sat, 01 November 2014, 03:02:32 »
Happy Halloween!
the greenish brobot near the palm, is that a riptide :O the colour looks amazing.
Offline HPE1000
  • Keycap Paparazzo
« Reply #857 on: Sat, 01 November 2014, 11:10:41 »
Happy Halloween!
Nah, it's a army man green.  :p
Here is another picture of it, still out of focus but the color might be better in this.
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #858 on: Sat, 01 November 2014, 11:16:45 »
Ducky Shine 4 @ Indonesia :D
Offline frosty
  • jukebox hero
« Reply #859 on: Sat, 01 November 2014, 11:18:03 »
Happy Halloween!
ah, love it. thanks!
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #860 on: Sat, 01 November 2014, 16:56:17 »
Making MX Clears with 100g springs :)
Offline Lastpilot
  • Power stance
« Reply #861 on: Sat, 01 November 2014, 20:15:29 »
Got some Cherry MX Red RGB switches today.
« Reply #862 on: Sat, 01 November 2014, 20:32:27 »
That's a really good use for those bags. I usually just throw them away.
Offline Lastpilot
  • Power stance
« Reply #863 on: Sat, 01 November 2014, 20:35:10 »
Hahaha, yes. If there's something unexpected that I learned from Geekhack, it's how to reuse packaging lol.
Offline Zeal
« Reply #864 on: Sat, 01 November 2014, 20:49:20 »
Are those really RGB switches? The pins look don't look bronzish, and the base looks like those Gaote switches.  :confused:
Has Corsair/Cherry been lying to us with their fully clear enclosures? :))
Offline Lastpilot
  • Power stance
« Reply #865 on: Sat, 01 November 2014, 20:51:08 »
Well I actually went out and purchased a K65 to harvest them, so they better be! They actually have a hole in the bottom to let the light shine through better. Also, as far as I can tell the top part is a new, stiffer material from the black housings we know. It was a bit harder to take them apart. The pins look typical silver color to me.
Offline Zeal
« Reply #866 on: Sat, 01 November 2014, 20:54:33 »
These macro shots are deceiving! Base of the switch doesn't look quite the same colour wise.
Offline Lastpilot
  • Power stance
« Reply #867 on: Sat, 01 November 2014, 20:57:12 »
Yep, those are definitely different from what I got. The ones I harvested have standard pins and a more opaque bottom enclosure. But yeah, it does have that hole where the led goes but on the bottom enclosure instead of the top.
At least the light from the K65 shines through them just fine, but yeah I was definitely disappointed once I saw the bottom housings. </3
« Last Edit: Sat, 01 November 2014, 20:59:14 by Lastpilot »
« Reply #868 on: Sat, 01 November 2014, 20:58:27 »
Zeal, I  think the product shots look different because of how they're lit.
Offline Lastpilot
  • Power stance
« Reply #869 on: Sat, 01 November 2014, 21:02:35 »
To clarify, here are the bottom and top housings separated:
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #870 on: Sat, 01 November 2014, 21:05:58 »
uniqlo <3
« Reply #871 on: Sat, 01 November 2014, 21:48:06 »
That's interesting.  Are they like the AboStudio tops then?
Offline Lastpilot
  • Power stance
« Reply #872 on: Sat, 01 November 2014, 22:05:22 »
They are actually much better than the AboStudio tops. They are made from a harder material but have similar levels of transparency.
Cherry is on left and AboStudio is on right.
Unfortunately I can't put them through stress tests because I need every cover that I have lol.
EDIT: Sorry, allow me to explain a bit further. You are probably wondering how I know that the Cherry tops are made from a harder material. When I take apart switches I use two small flathead screwdrivers to simultaneously loosen the "legs" from one side of the bottom housing. I found it much harder to flex the legs on the new cherry tops. Also, when I am taking apart switches using AboStudio tops I can almost ALWAYS find bend marks (white lines or auras) where the legs were flexed. This has yet to happen with me regarding the Cherry tops. :]
« Last Edit: Sat, 01 November 2014, 22:16:39 by Lastpilot »
Offline Veridis
« Reply #873 on: Sat, 01 November 2014, 22:24:11 »
Novatouch with white Leopold PBT
CM NovaTouch
Poor Man's RGB:
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
Offline Zeal
« Reply #874 on: Sat, 01 November 2014, 22:51:07 »
Thanks for the picture comparison! It seems like Cherry clear tops are a "warmer" shade of clear?
Offline ComradeSniper
  • HHKB Pro
« Reply #875 on: Sat, 01 November 2014, 22:55:32 »
CM NovaTouch
Poor Man's RGB:
Wow, beautiful pictures.
Offline jacobolus
« Reply #876 on: Sat, 01 November 2014, 23:13:58 »
The clear housings are presumably polycarbonate, while the black housings are.. Delrin? PBT?
Offline HPE1000
  • Keycap Paparazzo
« Reply #877 on: Sat, 01 November 2014, 23:18:44 »
Awesome pictures. 100g clears? How much heavier are they than stock clears?  :eek:
Offline frosty
  • jukebox hero
« Reply #878 on: Sun, 02 November 2014, 10:41:07 »
What would you be doing with those? Any build logs coming up? :D
CM NovaTouch
Poor Man's RGB:
Lol @ the Poor Man's RGB. Nice caps!!!
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #879 on: Sun, 02 November 2014, 12:30:31 »
It feels almost double heavier. Typing on it right now! It's like a training board, i'll need a sweatband for every finger :)
« Reply #880 on: Sun, 02 November 2014, 12:31:09 »
Is that OG skidata or Sherry's?
Offline BlueBär
« Reply #881 on: Sun, 02 November 2014, 12:43:57 »
There's a hint hidden in the center of the first picture.
« Reply #882 on: Sun, 02 November 2014, 12:47:00 »
Nope, still can't tell.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #883 on: Sun, 02 November 2014, 12:48:46 »
Is it because of ÖÄÜ? They are original SkiData caps (and a Code cap from the CMYK ESC / space bar mini group buy). Here's the complete build:
Offline BlueBär
« Reply #884 on: Sun, 02 November 2014, 12:49:37 »
Is it because of ÖÄÜ? They are original SkiData caps. Here's the complete build:
Yep! Looking good :thumb:
« Reply #885 on: Sun, 02 November 2014, 12:51:22 »
Learning has happened.
That's a good looking board.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #886 on: Sun, 02 November 2014, 13:00:26 »
The quality of the PCB and the aluminum plate is not really good, i had to re-solder 2 diodes, cut the aluminum plate because of ISO Enter not fitting perfect. The case is very nice, especially for its price; it's the 60$ 60% case from Pexon. Here's a close up from the cut aluminum plate:
Next time i will get a 60% PCB like the Nerd 60 or similar one for sure!
Offline Fnzzy
« Reply #887 on: Mon, 03 November 2014, 11:53:32 »
Looks great! I always thought OG Skidata was rare, who knew you can buy loads of it here! :p http://www.ebay.de/itm/SKIDATA-PS-2-MULTIMEDIA-MECHANICAL-KEYBOARD-TASTATUR-TRACKBALL-CHERRY-KEYS-PS-2-/310643702188?pt=DE_Computing_Tastaturen_Keypads&hash=item4853ceb9ac
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #888 on: Mon, 03 November 2014, 12:52:49 »
They used to be. Until that eBay seller got his hands on some stock. They were quite cheap at first, like €50 or so, then he found out why there suddenly was so much demand and he increased prices.
They're actually really fun boards, lubed MX Clears, pcb-mounted and screw-on stabilizers. And an awesome set of keycaps to boot. ;)
The layout is nice too:
|||My other keyboards :
x
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #889 on: Mon, 03 November 2014, 14:18:56 »
I think it's also with price tag now interesting - you get some nice caps (ISO DE or Nordic) and lots of MX Clear switches!
Offline tigersharkdude
« Reply #890 on: Mon, 03 November 2014, 15:44:03 »
Super bored = Galactus beauty shots ... lol
Offline Zeal
« Reply #891 on: Mon, 03 November 2014, 16:10:41 »
Forever #LEGITBALLIN
Stepping up the game  :cool:
Offline connorelsea
  • Java programming and fancy key caps!
    • Elsea Labs
« Reply #892 on: Mon, 03 November 2014, 17:15:35 »
Finally got the keys for my mechanical keyboard in the mail today, and that means that I am using a mechanical keyboard for the first time ever! It feels very nice and I have seen my typing speed increase from around 105 to 115 or so. But at first I was making a lot of errors. It is pretty difficult to adjust to the smaller form factor of my new keyboard.
Elsea Keys - Artisan key caps, keyboards, custom painting - Click any image to purchase or view
Offline frosty
  • jukebox hero
« Reply #893 on: Mon, 03 November 2014, 23:25:15 »
The colour is so... punchy! :)
The white background accents the switch and spring, beautiful shot m8!
Ah, feels like I could eat the cap!  :P
Offline nntnam
« Reply #894 on: Tue, 04 November 2014, 12:15:10 »
Some old photos, most of those are gone though  :(
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline Zeal
« Reply #895 on: Tue, 04 November 2014, 17:55:55 »
The picture was originally meant to emphasize my gold plated sockets for LEDs.  :p But I agree, it's a good picture! If only I had a macro lens....SoonTM
Offline frosty
  • jukebox hero
« Reply #896 on: Tue, 04 November 2014, 23:22:46 »
I love the first pictureeee
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #897 on: Wed, 05 November 2014, 14:34:25 »
Decided to make some pics of my Dyesub collection.
And this:
Had a few other shots but they didn't really work. I'll try again later.
x
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #898 on: Sat, 08 November 2014, 21:57:16 »
Playing around with the lighting:
Danbo is life.
Handstands are hard
PlayDanbo
Three's a party:
  • HHKB Pro
« Reply #899 on: Sat, 08 November 2014, 21:58:27 »
Wow, I need a Danbo.
