Author Topic: HHKB Pro2 USB Hub  (Read 11082 times)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
HHKB Pro2 USB Hub
« on: Fri, 24 May 2013, 09:53:22 »
Can the hub on the hhkb supply enough juice to read flash drive? When I plug my flash drive in I get "Not enough power for the device"...
Corsair survivor usb 3.0
-Enzo Ferrari
Offline SmallFry
Re: HHKB Pro2 USB Hub
« Reply #1 on: Fri, 24 May 2013, 09:55:05 »
USB 3.0 requires quite a bit more power, thus why the drive won't be read.
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #2 on: Fri, 24 May 2013, 10:01:50 »
They only provide 100mv I think, that is barely enough to keep a modern smartphone ticking over, never mind charging it a resonable rate. It is fine for a mouse, but nowhere enough for a USB Drive or a card reader.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #3 on: Fri, 24 May 2013, 10:07:16 »
:( useless hub on my hhkb.
possible to feed the hub more power?
-Enzo Ferrari
Offline SmallFry
« Reply #4 on: Fri, 24 May 2013, 10:08:58 »
Perhaps, but it'd require a mod. You'd need to somehow have external power for the USB.
Offline pexon
    • Pexon PCs
« Reply #5 on: Fri, 24 May 2013, 10:09:27 »
Nope, USB can only provide 500MV anywho. The hub is only good for mice really...  :(
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #6 on: Fri, 24 May 2013, 10:12:39 »
ok, thanks for the info.
Now I will be taking about this hhkb :D
-Enzo Ferrari
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #7 on: Fri, 24 May 2013, 10:23:11 »
I don't think it reads USB 2.0 either
Offline MJ45
  • HHKB Pro
« Reply #8 on: Fri, 24 May 2013, 17:01:04 »
I had only one usb 2.0 flash drive work on the HHKB hub, a Corsair Flash Voyager others not enough power most mice wont work and draw more than its 100ma. rating. The hub on the HHKB Pro 2 is pretty much a useless feature.
Offline Michael
  • Formerly Bro Caps
« Reply #9 on: Fri, 24 May 2013, 17:03:34 »
I use my mouse with it. That's what it's good for. Especially when using it on laptops with limited USB ports.
Offline MJ45
  • HHKB Pro
« Reply #10 on: Fri, 24 May 2013, 17:31:06 »
The mice I use a Steelseries Sensi or a Razer Taipan wont work, not enough power. I have not tried others, I have to plug my mouse in my laptop to use it.
Offline jalaj
« Reply #11 on: Fri, 24 May 2013, 17:35:35 »
Probably good enough for a wireless mouse's USB wireless receiver.
Offline Michael
  • Formerly Bro Caps
« Reply #12 on: Fri, 24 May 2013, 18:09:02 »
That's odd. I fail to see what makes the Sensei take more power than the Logitech G9X (which is what I am using on my HHKB USB port)
Offline MJ45
  • HHKB Pro
« Reply #13 on: Fri, 24 May 2013, 18:22:55 »
The MacBookPro system report on usb shows the Sensei requires 200mA the HHKB's is only100mA.
Offline esoomenona
  • Gnillort?
« Reply #14 on: Fri, 24 May 2013, 20:17:07 »
Well this sucks. This was literally one of the best things I was looking forward to about a HHKB... Now I don't know what to do.
Offline Michael
  • Formerly Bro Caps
« Reply #15 on: Fri, 24 May 2013, 20:18:19 »
lol
Offline phoenix1234
« Reply #16 on: Fri, 24 May 2013, 22:16:17 »
My advise is not to share high power consumption via the spare port of keyboard.
For laptop, I will use usb hub to share:
http://www.belkin.com/us/p/P-F5U407
For desktop, I will use powered-usb-hub to share:
http://www.belkin.com/us/F4U041-Belkin/p/P-F4U041
I like linear switches
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #17 on: Sat, 25 May 2013, 02:45:39 »
There is very few devices that work with HHKB hub. Only things I could get to work were mice and headphones (crappy logitech ones, nothing fancy).
