Author Topic: MX Clear Longevity  (Read 1574 times)
Offline nsrexler
MX Clear Longevity
« on: Fri, 24 May 2013, 10:51:27 »
I've heard that MX Clears tend to wear out and become more linear over time due to friction, but how long does that usually take? I'm wondering how much life I can expect to get out of this Ducky before I'll have to replace it.
Re: MX Clear Longevity
« Reply #1 on: Fri, 24 May 2013, 10:52:29 »
years and years and years
« Reply #2 on: Fri, 24 May 2013, 10:53:49 »
Doesn't Cherry rate all their switches at 50 million presses?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #3 on: Fri, 24 May 2013, 10:54:29 »
Apparently POS boards with clears start feeling like stiff browns after 20+ years.
|||My other keyboards :
x
« Reply #4 on: Fri, 24 May 2013, 10:55:05 »
cherry does not rate the "bump" of the switch to 50 million, only the longevity of the actuation process.
« Reply #5 on: Fri, 24 May 2013, 11:01:44 »
Hm, that's good to know. I think 20 years is an acceptable life span for my boards though ^__^
Offline Larken
« Reply #6 on: Fri, 24 May 2013, 11:04:12 »
I wouldn't worry about the number of years you can get out of a keyboard switch. It's more likely the electronics will fail way before the stems wear down. *fingers crossed*
After twenty years, people might be searching for 'vintage clears' if we are still using keyboards by then.
| Ergodox #1 | Ergodox #2 |
