Author Topic: QuickFire Rapid Replacement Top Panel - $9.99 (50% off)  (Read 4479 times)
Offline missalaire
  • Great Finder of Great Finds
Re: QuickFire Rapid Replacement Top Panel - $9.99 (50% off)
« Reply #1 on: Sat, 25 May 2013, 11:51:34 »
Will this top fit on a filco bottom?
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #2 on: Sat, 25 May 2013, 11:56:30 »
i dont think so, the bottoms are really different, but i could be wrong im sure someone will confirm, i have a niggling feeling i have heard they do and im being an idiot
« Reply #3 on: Sat, 25 May 2013, 11:58:32 »
Well I've got plans to butcher a case top so this would be ideal.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #4 on: Sat, 25 May 2013, 13:20:56 »
Hmmm I'd also be very interested to know if this will fit on a Filco TKL. If so, definitely in for one!
Offline OddOne
« Reply #5 on: Sat, 25 May 2013, 13:41:06 »
I picked up 2 of these last night to replace my branded ones. If you want to just butcher one, I could probably hook one with one of my old ones for cheaper then paying from CM plus their shipping. PM me if interested.
CM Quickfire Rapid   |   Rosewill RK-9000BR  |  CM Quickfire Rapid  |
Offline Badwrench
  • ummmm.....I forgot
« Reply #6 on: Sat, 25 May 2013, 13:54:32 »
Let me know if you have one left after ray?
I want to butcher one as well >:D
Offline AKIMbO
  • HHKBro
« Reply #7 on: Sat, 25 May 2013, 15:55:42 »
Yes they do fit.  I've had a QFR top on a Filco bottom and vice versa.  I had to shave off one plastic PCB standoff on the bottom of one of the cases (forgot if it was Filco or QFR)....but it will fit.  Assuming that you are using a filco USB cable and not the QFR daughter board.
| KBD75 (box reds)
« Reply #8 on: Sat, 25 May 2013, 15:57:52 »
Thanks so much for the information.
i would be using it for a phantom, think that would work?
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #9 on: Sat, 25 May 2013, 16:01:22 »
Thanks for the info! I'll forward to trying to fit my QFR top on my Filco that's coming in :)
« Reply #10 on: Sat, 25 May 2013, 18:14:02 »
I went ahead and ordered four :P
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #11 on: Sat, 25 May 2013, 18:26:00 »
I'll look forward to seeing what you do with them :) assuming that you are going to experiment :P
« Reply #12 on: Sat, 25 May 2013, 18:56:12 »
....for keyboard science!
Offline Latin00032
« Reply #13 on: Sat, 25 May 2013, 20:14:09 »
Bedazzle?
Offline Toad1677
« Reply #14 on: Sat, 25 May 2013, 20:54:56 »
Great find. Just picked up a black one to replace the stock gray one on my QFR ;D  Just wish shipping was cheaper and I had to pay taxes  :confused:
« Last Edit: Sat, 25 May 2013, 21:02:47 by Toad1677 »
QFR MX Blue, Blackbird MX Blue, KBP V60 MX Green, KUL ES-87 MX Green, Pok3r Mx Clear
Offline shadewolf
  • ಠ_ಠ
« Reply #15 on: Sat, 25 May 2013, 21:07:59 »
Woo, in for a couple. Thanks!
