Author Topic: Where are the MX Greens?  (Read 2087 times)
Offline DrinkTea
« on: Sat, 25 May 2013, 17:59:43 »
I'd really like to try a keyboard with MX green switches, but they seem to be out of stock everywhere. Ideally, a tenkeyless one, but those (and seemingly everything else for that matter) are nowhere to be found. Does anyone have an idea of when and where they'll be available again?
Also, how about something with clears? Thanks.
Offline GeoTang
Re: Where are the MX Greens?
« Reply #1 on: Sat, 25 May 2013, 18:19:28 »
« Reply #2 on: Sat, 25 May 2013, 18:22:00 »
http://www.amazon.com/CM-Storm-QuickFire-Rapid-Mechanical/dp/B00C2MBG2U
These are in stock and TKL :o
Usually ships in 1 to 3 months
You can get the new Leopold from qtan with clears
mechanicalkeyboards.com had some recently but they are currently out of stock
« Last Edit: Sat, 25 May 2013, 18:26:01 by ray4jc »
Offline DrinkTea
« Reply #3 on: Sat, 25 May 2013, 18:29:46 »
Is there a clear model that's tenkeyless (or smaller)? What does the leopold cost?
Offline GeoTang
« Reply #4 on: Sat, 25 May 2013, 18:36:02 »
Yeah...
But, from my quick browsing, it's the only place to even place an order atm.
Oh, after some further googling, apparently greens won't be in stock till August (for CM)
Offline linziyi
  • The one with many questions
« Reply #5 on: Sat, 25 May 2013, 18:40:09 »
Yeah...
Another option would be the Ducky DK9008 G2pro coming in mid june, with thick PBT!
I think you can pre-order now http://www.jimms.fi/tuote/DK9008G2PRO-GFIPHH
Ducky DK9008G2 Pro
"Much to learn you still have" --Yoda
Offline Turkishrambo
« Reply #6 on: Sat, 25 May 2013, 18:42:20 »
http://www.canadacomputers.com/product_info.php?cPath=21_273_274&item_id=059840
Offline GeoTang
« Reply #7 on: Sat, 25 May 2013, 18:44:58 »
^ They only ship to Canada :C
Offline jabar
« Reply #8 on: Sat, 25 May 2013, 18:46:51 »
Cooler Master will have a much wider selection and stock of MX Green boards since they are doing this sort of exclusive arrangement with Cherry for the US.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline kelske
  • The North Borders
« Reply #9 on: Sat, 25 May 2013, 23:10:58 »
MK still had stock of the QFR with greens until early this week. CoolerMaster don't seem to be running the Green switched boards as a Limited Edition or anything, should hoepfully be back in stock sometime soon :)
Offline GeoTang
« Reply #10 on: Sun, 26 May 2013, 01:06:03 »
ignore~
« Last Edit: Sun, 26 May 2013, 01:09:15 by GeoTang »
