Author Topic: IBM TrackPoint questions . . . .  (Read 1662 times)
Offline dante
« on: Sun, 26 May 2013, 09:15:02 »
1. When it comes to IBM rubber domes there seems to be 3 keyboards with trackpoint: The 8923, the RT3200 ][ spacesaver, and the little 'M4' buckling sleeve.  How would you rate these with the most important factor being the quality of the trackpoint?
2. How does the Unicomp Enduropro's stick handle?  If it sucks can it be modded in any way?
That is all for now...
« Last Edit: Sun, 26 May 2013, 09:36:32 by dante »
Offline davkol
  •  Post Editing Timeout
Re: IBM TrackPoint questions . . . .
« Reply #1 on: Sun, 26 May 2013, 09:47:37 »
Trackpoint on the EnduraPro is quite nice if you put thinkpad classic dome on it... as long as you don't use any higher screen resolution. However, its buttons are the worst I've ever used. Ridiculously stiff. I haven't had time to take it apart, but I guess they could be modded.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Sun, 26 May 2013, 15:51:52 »
If it's not a TrackPoint II it's awful. The end. They're all TrackPoint original which has a pretty "meh" strain sensor. The only one worth owning for a modern system is the buckling spring TrackPoint II and it's pretty meh as well since it has no inertia support. At all. Period. Zero zip zilch nada none.
As far as the EnduraPro goes? Honestly, don't bother. It's a cheaper version of the TrackPoint II in a modified M2 shell basically. It addresses the manufacturing difficulty of the M13/TrackPoint II chassis with regards to the button area reasonably well, but it's still an old TPII to the core.
As far as modifying the TPII/EnduraPro? Nope. Don't even bother considering it. The buttons are on matrix lines, and if you mess with that, you'll mess with the behavior of the TP itself. The matrix lines are an integral component of the design somehow and any sort of tampering with them tends to have exceedingly bad results.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline 1cc
« Reply #3 on: Mon, 27 May 2013, 09:17:29 »
If those all "meh", what are the good ones?
