Author Topic: Nexus 4 problems....or are they problems  (Read 1825 times)
Offline yester64
« on: Sun, 26 May 2013, 14:50:49 »
I noticed that sometimes my Nexus has some issues with the datastream. For some reason unknown if i turn off Wifi the data connection is somehow gone and doesn't come back for a while. The indicators do work though.
But more annoying is that sometimes that datanetwork is gone for no apparent reason. Since i am on Straighttalk i like to think it may be my carrier, but i do have all the signal thats out there.
Does anyone have a similar problem?
How long does anyones battery last with everything on (like sync). Mine will last max a day. In the morning full and by work days end about 30%. I have normally everything on. After all whats the point to disable something what is part of a "smart"phone. Just comparing so to know that i am in the normal on that.
Rosewill RK-9000BR (trashed)
WASD V1 Keyboard Cherry Blue w/40A Hardness O-Rings
Steelseries 6GV2 Red Cherry Switches
