Author Topic: CM Storm Trigger compatible with Ducky Shine Keycaps?  (Read 4138 times)
Offline bigmilk
« on: Mon, 27 May 2013, 08:36:11 »
Hi, I was looking at the CM Storm Trigger, I'm thinking about purchasing, however are there any keycaps that are compatible with it?
http://www.ebay.co.uk/itm/Purple-Ducky-key-caps-for-Ducky-Shine-mechanical-keyboard-MX-cherry-switches-/290920986179?pt=LH_DefaultDomain_0&hash=item43bc3df643
Would the Ducky Shine custom keycaps be compatible with the keyboard? I don't see why not, considering the light shines through both the Shine and the Trigger's keycaps?
I'm looking to go for a decent keyboard with 1ms latency, so the CM Storm Trigger is right up my street, not too keen on the CM Storm Trigger's back-lighting when compared to Ducky's, but for the price compared to the Ducky Shine II, it's a safe bet. Unless there are any alternatives someone could suggest?
Offline AGmurdercore
Re: CM Storm Trigger compatible with Ducky Shine Keycaps?
« Reply #1 on: Mon, 27 May 2013, 08:40:13 »
Yeah, they should be
What the hell am I even doing
Offline bigmilk
« Reply #2 on: Mon, 27 May 2013, 10:04:16 »
You sure? I mean, apart from the keyboard's lettering design, is there any difference in shape between the keycaps?
« Reply #3 on: Mon, 27 May 2013, 10:33:19 »
Well i cant be 100% but i am like 99% that they will fit the board and everything will be just fine :P
« Reply #4 on: Mon, 27 May 2013, 10:34:34 »
They will work fine as long as the Trigger has a US-ANSI layout.
« Reply #5 on: Mon, 27 May 2013, 11:27:32 »
The Storm trigger has extra macro keys.
Offline LinkPro
« Reply #6 on: Tue, 28 May 2013, 16:54:11 »
They should fit just fine, if there is anything to worry about it's probably the keycaps' height.
Offline Photoelectric
« Reply #7 on: Tue, 28 May 2013, 23:06:48 »
I believe both should be of the same height / profile (OEM).  The 5 macro keys can always get some other cool caps.
