Author Topic: Best wrist rest for SSK/KMAC? Can't be cloth because hands sweat so much!  (Read 1423 times)
Offline HolidaySHRIMP
I currently have one of the Grifiti Wrist rests from Amazon that has worked wonderfully for my HHKB.  Given it's price it's a great steal.  However, it has split apart (cloth top layer from foam) due to my hyperhidrosis (excessive sweating of the hands/feet).  Also using it 10+ hours a day (work/play) doesn't help.
Now that I have two fancy keyboards I'm looking for something long term, better quality, and more fitted to the TKL size. I really like Beasts work, but I don't see anything that will match with blue or anything available to buy now.  The only off the shelf I only see available online are the Filco and Ducky ones.
http://www.amazon.com/Filco-Leather-Wristrest-Compact-Keyboards/dp/B001EY9RJQ
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=136
Too bad that group buy died, because I had my color scheme all picked out for all my keyboards :(
Offline Badwrench
  • ummmm.....I forgot
Pm beast and see if he can make you one in Maple with a blue stain?
