Author Topic: Anyone know anything about this keyboard?  (Read 2068 times)
Offline Repress
« on: Mon, 27 May 2013, 19:03:13 »
I was at a local thrift shop and picked this up on a whim, just wondering if it was worth keeping.
I dont know much about mechanical keyboards as i have used rubber dome's all my life but it sounded nice and clicky like you would expect a mechanical keyboard to.
Identification on the back says Clevo CO. FCC ID FMA44H
EDIT: having trouble attaching the photo's ive uploaded them here.
http://imgur.com/a/thxof#0
« Last Edit: Mon, 27 May 2013, 19:06:43 by Repress »
Offline MJ45
  • HHKB Pro
Re: Anyone know anything about this keyboard?
« Reply #1 on: Mon, 27 May 2013, 19:22:16 »
The best way to find out if its mechanical is pull a keycap to find out what switches it has. Post a pic of them someone will help I.D. it.
Offline Repress
« Reply #2 on: Mon, 27 May 2013, 19:54:02 »
Popped off a keycap and it seems they have White Alp Switches? it says  2a54 on the black portion underneath.
« Last Edit: Mon, 27 May 2013, 19:56:43 by Repress »
« Reply #3 on: Mon, 27 May 2013, 19:54:13 »
I knew that I had seen it before, so I went to look. Webwit over on Deskthority has posted about it:
Reveal KB-7061 (Complicated white Alps, double shot keys, also marketed under different brands, cheap construction)
Offline Repress
« Reply #4 on: Mon, 27 May 2013, 20:00:59 »
Just wondering, worth anything on ebay? I mean i got it for 5 bucks and they had several left. I personally dont care for ergonomic keyboards if its worth anything id go pick up the rest of them and sell them on ebay and pick up a different keyboard.
