Author Topic: HPE 87 Brown - Key Stroke Sounds Quieter than other Brown boards  (Read 2170 times)
Offline morpheus
Lately I've been watching some videos of various MX Brown boards, and for some reason they sound much louder than my HPE 87 Browns.
For any Brown aficionados, can you confirm this?
Offline ksm123
Re: HPE 87 Brown - Key Stroke Sounds Quieter than other Brown boards
« Reply #1 on: Tue, 28 May 2013, 07:46:38 »
Do not trust the volume on videos. How would you calibrate volume levels on a home made video? What would you use as a reference?
Most videos are made with poor quality web-cams without dedicated mike. This setup guarantees poor quality of sound.
Loudness of Brown Switch depends on your typing technique. The same keyboard can be much louder if used by another typist. I did some tests using Noppoo Choc Mini and an mark I eardrum, my friend who bottoms out heavily, types much louder then myself.
Offline Tym
« Reply #2 on: Tue, 28 May 2013, 07:47:13 »
Maybe grab a switch pack of WASD and have a comparison ?
Offline morpheus
« Reply #3 on: Tue, 28 May 2013, 08:09:18 »
You know what, you're absolutely right. You can't trust the volume on the videos. I guess it depends on the quality of the video/sound. Also, I don't bottom out as hard or as frequently as some of the people in the aforementioned videos.
Thanks for the insight.
Offline Larken
« Reply #4 on: Tue, 28 May 2013, 08:14:40 »
Same switches would sound different on different boards. A few factors that affect the sound would be these -
1. Keycaps - thickness, profile, material etc.
2. Whether board is plate mounted or simply pcb mounted.
3. The acoustic properties of the keyboard case - design, material used etc.
For example, my filco brown sounds and feels slightly different from my ducky browns - two boards I have side by side.
There are several other things (lubing, stickering to name a few) that could alter the sound of a board, but those would pertain to modified boards instead.
| Ergodox #1 | Ergodox #2 |
Offline baller1308
« Reply #5 on: Tue, 28 May 2013, 09:34:38 »
I found that the sound of the HPE is quieter compared to my other boards.  The other boards are older though, so I'm not sure if that is a factor.  But, I think over time the HPE board will be just as loud as the other boards.
I think it's the build quality too, because even if bottom out on the HPE board it doesn't sound as loud as my Noppoo Choc Mini or Rosewill board.
Noppoo Choc Mini [Browns]
HPE 87 [Browns]
Offline morpheus
« Reply #6 on: Tue, 28 May 2013, 10:03:58 »
Does that mean the build quality on the HPE is better or worse than the other boards because it's not as loud?
Offline Badwrench
  • ummmm.....I forgot
« Reply #7 on: Tue, 28 May 2013, 10:08:53 »
I don't think better or worse, just different.
Also, don't forget other things that affect the sound such as the desk you are sitting it on, and the acoustic quality of the room you are in.
Offline dante
« Reply #8 on: Tue, 28 May 2013, 18:50:30 »
Also note: there can sometimes be acoustic differences between fullsize and tenkeyless.
