Author Topic: Switches available for Cherry G80-3000?  (Read 1831 times)
Offline jksteger
« on: Tue, 28 May 2013, 10:18:01 »
I have a cherry G80-3000 with blue switches.  I love the board and the large case compared to today's smaller cases.  What switches are available for the Cherry G80-3000?  I would like to have this board with brown's or even red's.  Otherwise, since they switches are board mounted and not plate mounted, which cherry POS board could I find on the cheap to rob some brown or red switches from?  Thanks,
J.
Offline davkol
  •  Post Editing Timeout
Re: Switches available for Cherry G80-3000?
« Reply #1 on: Tue, 28 May 2013, 10:39:15 »
G80-3000 is available with blacks, blues and sometimes clears. It existed with browns, but only in Asia IIRC. For reds, see G80-3494LYCUS. If you want to just replace switches, make ghetto reds (black stem + some lighter spring) instead of buying regular reds. Browns are rather hard to get, maybe salvage an old Compaq MX 11800.
Offline jksteger
« Reply #2 on: Tue, 28 May 2013, 10:58:55 »
davkol,
do the black and red share the same stem (color difference only) and only have different springs?
Offline davkol
« Reply #3 on: Tue, 28 May 2013, 11:22:08 »
Yep.
Offline Masterchief79
« Reply #4 on: Tue, 28 May 2013, 12:35:51 »
In fact, Browns, Blues and Reds all have the same springs, and I think also Blacks and Clears? Not sure about the last one though.
Taiwanese Fake-Model F with MX black copies (1984) | Apple Keyboard (salmon Alps 1987) | G80-1000HDD vintage blacks (1987) | G80-1000HFD vintage blues | G80-1800HFD | QPad MK50 browns | AEK II
Offline davkol
« Reply #5 on: Tue, 28 May 2013, 12:37:07 »
Nope, springs in MX Clear are quite specific.
