Author Topic: Realforce Numpad  (Read 2829 times)
Offline longweight
  • philanthropist
Realforce Numpad
« on: Tue, 28 May 2013, 14:57:13 »
Hi all,
I am very close to ordering one of these :D I do have a question about replacing the caps.
The Numpad has three 1x1 caps along the bottom:
All of the keycap sets seem to have a long 0 cap as per the standard Topre boards:
Is this the case? Or is there an extra cap with the blank keycap sets that EK sells?
Offline esoomenona
  • Gnillort?
Re: Realforce Numpad
« Reply #1 on: Tue, 28 May 2013, 14:58:27 »
You're not also worried about the top four caps being different as well?
« Reply #2 on: Tue, 28 May 2013, 15:00:01 »
Well if my first topre board gets me hooked I'll either need one of these and/or a full size board :eek:
Offline longweight
  • philanthropist
« Reply #3 on: Tue, 28 May 2013, 15:01:02 »
Offline SmallFry
« Reply #4 on: Tue, 28 May 2013, 15:03:32 »
Fill it with Topre novelty keys. Oh wait... :P
Offline longweight
  • philanthropist
« Reply #5 on: Tue, 28 May 2013, 15:06:21 »
I don't want it to look like an arcade machine :)
I might just sand down the caps so that they are blank.
Offline longweight
  • philanthropist
« Reply #6 on: Tue, 28 May 2013, 15:08:45 »
Just realised that the replacement cap sets do come with those four caps.
Offline SmallFry
« Reply #7 on: Tue, 28 May 2013, 15:10:31 »
Which four caps are we talking about now? The top ones or the bottom ones? I've been thinking of getting a RF keypad, since there doesn't seem to be one perfect MX one. Perhaps I should look into ALPS before Topre, price wise.
Offline longweight
  • philanthropist
« Reply #8 on: Tue, 28 May 2013, 15:11:09 »
The four caps along the top....
Offline esoomenona
  • Gnillort?
« Reply #9 on: Tue, 28 May 2013, 15:12:40 »
Where? Also, if anything, you could just buy a blank set and use whichever caps you wanted wherever you wanted them.
Offline SmallFry
« Reply #10 on: Tue, 28 May 2013, 15:12:46 »
Gotcha. Where are you planning on sourcing such a beast. EK doesn't have them anymore. Secondhand?
Offline longweight
  • philanthropist
« Reply #11 on: Tue, 28 May 2013, 15:13:26 »
