Author Topic: Screw you lexmark...that is all (previously unseen m15 internals)  (Read 2174 times)
Offline RougeR
HOW THE **** DO I GET THIS MOTHER ****ING BACKPLATE OFF WHY THE **** WOULD YOU DO THIS.
took my m15 apart dislodging three springs/flippy plate things, now i cant find one of the flippy plates in the keyboard, another is outside it and another is stuck unatatrched.
FML.
i need to take the backplate off but its attached by these mother****ing devil things,seriously...USE ****ING SCREWS!
« Last Edit: Tue, 28 May 2013, 16:46:52 by RougeR »
Buckling spring warrior!
Offline RougeR
Re: Screw you lexmark...that is all
« Reply #1 on: Tue, 28 May 2013, 16:34:46 »
IM IN! ****ing burnt my way in and destroyed the rivets.
Offline RougeR
Re: Screw you lexmark...that is all (previously unseen m15 internals)
« Reply #2 on: Tue, 28 May 2013, 17:10:20 »
Offline RougeR
« Reply #3 on: Tue, 28 May 2013, 17:12:12 »
this and a metallic clip are the culprits
Offline Ninjerk
« Reply #4 on: Wed, 29 May 2013, 19:18:47 »
Nice. Yeah, I had a board I needed taken the backplate off....I just gave up on it and cleaned up another board for use.
Offline calavera
« Reply #5 on: Wed, 29 May 2013, 19:20:35 »
Why'd you open it in the first place, to clean/lube?
Offline RougeR
« Reply #6 on: Tue, 04 June 2013, 13:07:55 »
mods. goddamn mods.
