Author Topic: Greetings  (Read 1755 times)
Offline Fawksie
Greetings
« on: Tue, 28 May 2013, 18:31:41 »
Hello!
I'm a long time Model M coveter who finally bit the bullet. I've just finished cleaning up a 1986 Model M terminal board. I've built a Soarer's Converter in an external box. It will be used to fill my need for dozens of function keys at work (in a noisy open-plan office where it hopefully won't be noticed).
Photos
Evidently it had been cleaned externally by the seller, when it arrived it was sparkling and even smelled clean. Unfortunately the innards were covered in a thick layer of sticky brown cigarette tar. I managed to stretch the spring on the PF3 key when I caught it with a fingernail, awaiting replacements in the post.
Some vital statistics:
Overall assembly
The label is quite badly faded and there is no visible date of birth.
Part number: 1389188
Type: 3179
Model: KB6
Inner keyboard assembly
Backplate stamped "25 JUL 1986"
Backplate part number: 1351173
There are two labels on the rear, one on top of the other.
Original label: "1389147 SWISS/GER 09/26/86"
New label: "1389189 UK RECAP"
Controller
PCB part number: 1387223
IC part number: 1389363
Offline esoomenona
  • Gnillort?
Re: Greetings
« Reply #1 on: Tue, 28 May 2013, 18:34:03 »
Welcome! It makes me feel inadequate that on your first post, you've mentioned building a Soarer's Converter, when I still have yet to do so...
Offline Fawksie
Re: Greetings
« Reply #2 on: Tue, 28 May 2013, 18:43:56 »
Cheers! It's relatively easy when he's already done the hard work :D
