Author Topic: Looking to buy Realforce 87U Tenkeyless 55g (Black)  (Read 2073 times)
Offline libo720
« on: Tue, 28 May 2013, 19:35:52 »
Hi guys, i have decided to buy a Realforce 87U Tenkeyless 55g and i am just wondering if Elitekeyboards is the only place to get them. Are there any other cheaper sources to get a brand new one with the key puller, red esc key, and lavender wasd keys?
Offline jabar
Re: Looking to buy Realforce 87U Tenkeyless 55g (Black)
« Reply #1 on: Tue, 28 May 2013, 20:04:56 »
EliteKeyboards is the only US distributor. Otherwise ordering from Leopold in Korea is an option. I think there are other EU and Australian distributors but I'm not entirely sure.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
« Reply #2 on: Tue, 28 May 2013, 20:10:04 »
PCCG has white 87U, albeit variable, for AU$179.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=113_1297&products_id=18678
I don't know if you get the extras, but they wouldn't be difficult to find from elsewhere anyway.
Offline khaangaaroo
« Reply #3 on: Tue, 28 May 2013, 20:32:12 »
Yeah, EK is the easiest option if you want to buy new. Most alternatives involve importing.
Buying used from another GH member will get you the best deal. Although I haven't seen many 55g boards in the classifieds lately.
I have an extra set of lavender wasd and red esc if you need them. I'm sure other do too. But you should definitely throw the keypuller away if you get one. The only thing it's good for is scratching key caps. Actually, it might be good for removing jumpers from motherboards, but that's it.
« Reply #4 on: Tue, 28 May 2013, 21:15:03 »
Is there any particular reason the OP and anyone else in general goes for the uniform Topre boards?
As opposed to the variables?  Seems only variable keyboards are available locally for me.
Offline jabar
« Reply #5 on: Tue, 28 May 2013, 21:16:08 »
Variables are best for typing. Unfortunately the weighting varies over the WASD cluster which some here have reported being noticeable.
Phantom 7bit
« Reply #6 on: Tue, 28 May 2013, 21:39:08 »
WASD - which would affect people using such a keyboard for gaming purposes.
Fair enough.
My typing style is sufficiently chaotic that I don't always touch type, and tend to use whatever finger is closest for any key.
