Author Topic: Hello, need help with a new keyboard :D  (Read 8764 times)
Offline Photoelectric
Re: Hello, need help with a new keyboard :D
« Reply #50 on: Sun, 02 June 2013, 01:03:16 »
I saw this keyboard https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=178 i heard its recommended but i dont see why it costs that much no macros no anything just switches :/
I think i will take k70 or something.. Tell me what you think
Full backlight, high quality.
Offline Xtract
« Reply #51 on: Sun, 02 June 2013, 08:06:51 »
Twice the price of the cm
« Reply #52 on: Sun, 02 June 2013, 09:53:03 »
CM Quickfire Rapid has no backlight modes.  Also not the same quality (PCB, construction).  There are non-LED Ducky models which are around $100 and are thus close to what CM sells Rapids and Stealth  for on their own store site.  There's also a more budget friendly Ducky Zero line for under $100, and the TKL version of that is coming out soon.
Offline Rule16
  • R.I.P. SmallFry
« Reply #53 on: Sun, 02 June 2013, 22:07:46 »
Backlit keyboards are more expensive, if you don't like that, get a CM QFR.
« Last Edit: Mon, 03 June 2013, 11:36:35 by Rule16 »
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline jabar
« Reply #54 on: Sun, 02 June 2013, 22:13:07 »
Then get the CM QFR. Or get the Trigger if you want red backlight.
Prices are what they are for the backlighting. It's a lot more solder work and an extra daughterboard to manage LED control & save settings. I think there's enough posts to explain this to you.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Xtract
« Reply #55 on: Mon, 03 June 2013, 23:50:37 »
« Reply #56 on: Mon, 03 June 2013, 23:58:54 »
« Reply #57 on: Tue, 04 June 2013, 00:05:30 »
If you want people to spend time replying with advice, you should spend time reading it carefully and responding in kind.
Offline Lycoth
« Reply #58 on: Tue, 04 June 2013, 10:44:01 »
Ducky are one of the extremely well respected brands. Their general build quality and feel is widely considered to be one of the very best in Cherry MX Switches along with Filco.
If you're going to take one of the more mainstream brands like Corsair, have a look around on here and ask for opinions first, as some of them suffer from bad build quality. I can't speak for Corsair, but I know my Razer keyboard which I got because it's a brand most people know of, was pretty poor, and broke in a short amount of time.
I expect Corsair will be better though, they don't often cut corners on any of their products.
Offline domoaligato
« Reply #59 on: Tue, 04 June 2013, 11:08:26 »
cm storm trigger with your choice of switch seems to be what people recommend to noobs
The trigger is a nice keyboard.
I have no idea why you would post this.
It is targeted at the gamer community because of the software.
Based on what he posted
5 dedicated macro keys
6KRO
backlit w/3 brightness levels
fully programmable (assign/reassign macros or single functions to any keys)
here is a youtube video with a brief overview of the software if the OP is interested
« Reply #60 on: Tue, 04 June 2013, 11:18:57 »
This thread is just full of that sort of thing...  Which is unfortunate.
Offline domoaligato
« Reply #61 on: Tue, 04 June 2013, 11:33:32 »
His bias towards buckling springs (Model-M's) does not help this thread or the OP.
